Dont record .On the display apears protect
Most likely you have the tab in the minidisc set to protect preventing the recorder from recoding on the disk C11 is the same as Protected.
Slide the notch on the minidisc to the other side to record. You cannot record on pre recorded minidiscs. You have to remove the disc from the recorder to do this.
If you open theprotect tab the recorder may write over what you already have on the minidisc.
SOURCE: The recording level on my mds-je480 seems to be restricted
First of all, the remote has nothing to do with anything. Neither does the PEAK HOLD function.
Apparently, your source is not putting out a lot of signal. Check to see if it has a volume control. Or that you are connected to the right output (line level and not headphone out, for instance).
Of course, you can always turn up the recording volume on the 480. That's what it is there for. You can go up 12dB, which is plenty. And you can turn that up with the remote or with the AMS dial.
