Question about Gateway Solo 5300 Notebook
Computer problems Where can I buy that disk for the computer? Someone told me it wasn't hard once I get the right disk. I just don't know what to buy or where. Thank you for your help.
  • 538 Answers
You can most likely go back to, enter support, enter your model number, then see if they have an offer for a cd replacement service..
it is not hard..just takes around 1 and a half hours..
Posted on Oct 20, 2008
I purchased this router from someone and they told me it wasn't used. Turns out it was and now I don't know the log in information to set it up to my computer. Can this be reset without having to...
There is a reset button on the back. Press and hold that button (will require the end of a paper clip to get to it) for 20 seconds until the unit resets. The settings will be restored to the original factory defaults. The IP address will be and the password will be admin (no user name).
Jun 20, 2011 | Linksys Wireless-G WRT54G Router
Tombraider underworld has started to run slow
Before you start any game, this is what I do:
1.)Hold down the Ctl button and push the Alt key and delete button.
2.)Once you have Task Manager running click the Processes tab.
3.)Right-click and choose End Task on any extra software programs you don't need, and make sure you save and quit any other programs which are open and you don't need.
4.)That usually frees up alot of memory from bloatware (extra software you never even knew ran in the background of the computer and that you don't need).
5.)If you don't know which to close down, try them out, for sure you need to keep open explorer.exe because that's your computer.
6.)If that doesn't improve it much, run a disk clean-up by going into My Computer, Right-Click on your hard drive which has the game installed on it (normally drive C) and click the Disk Cleanup button under the General tab.
7.)Finally also under that properties window you can go to the Tools tab and do a disk defragmentation.
8.)Restart once its done, but down forget to close all the bloatware again from Task Manager.
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
Jun 04, 2011 | Computers & Internet
Toshiba (MK1031GAS) 100 GB Hard Drive - Cant be viewed in My comp
The first thing you need to do is go into the Control Panel, then double click on Administrative Tools. After that, open up Computer Management, then go to Storage, then Disk Management. This is where you will see all of your drives listed. Be extremely careful in this section because you don’t want to screw up your main hard drive.
What you are looking for in the Disk Management area is your new hard drive. If you only have one hard drive, it should show up as Disk 0. Therefore, your new drive should most likely be Disk 1. Underneath the name Disk 1 it should say Unknown, the size of the disk, and Not Initialized. Right click in this area and you should get a pop-up window. Click Initialize Disk and it should only take a couple of seconds.
Once your new hard drive is initialized, you will still have to format the drive before you can use it. To format, right-click in the column to the right of the Disk 1 label and then click New Simple Volume in the menu that pops up. From here, you can allocate how much of the drive you want for a new volume, what drive letter you want to call it, give it a name, and finally format the hard disk.
Formatting the hard drive may take a while, depending on the size. My 500 gigabyte drive took nearly an hour to format, so don’t be alarmed if your's takes a while. Once the format completes, your new hard drive will now show up in My Computer and you can start putting files on it.
Dec 24, 2009 | Toshiba (MK1031GAS) 100 GB Hard Drive
I was told my laptop now needs a new hard drive, but the tech suggested I not bother trying to have it fixed. A new hard drive wouldn't be expensive but the labor to put it on is twice as much. What do you...
Sata hard drives are available but the installation and all that are cumbersome . I think you should go ahead and upgrade and you can sell this off for some money as well . My point of view anyway . You can llok for sandisks or wd second hand drives. SHould be good.
Oct 21, 2009 | Toshiba Satellite 1405-S151 Notebook
Using aol computer check up .. i get reply that hard disk is almost full.. one click fix provided does not resolve problem .. what alternatives are available ? thank you
From my-computer right click on on hard-disk / properties this will show you how much free space available. Windows has system tools to check your hard disk for problems, like scan disk, disk cleanup, and disk defragmenter. Click start/hellp and support for more info. If you don;t find what you need let me know. Larry
Mar 08, 2009 | Computers & Internet
Hard disk problem(locked by a password)
Hi Someone has set the hard disk password in the BIOS. This stops the hard disk from being accessed until the password is sent to it. The hard disk itself is now locked - you cannot put it in another system - it will just not work until it receives the correct password. I am sorry but unless you know the password there is no way to access the data on the hard disk. You would have to send it to a data recovery firm or possibly return it to the disk manufacturer but contact them first as they will probably destroy all the data on the hard disk. Sorry - but you will have to buy  new hard disk and reset the CMOS before you fit the new one and remove all BIOS passwords.
Jan 26, 2009 | Toshiba Tecra S2 Notebook
Sony Viao issues
if ur getting the blue screen and it shuts off then definately the hard drvie but onething u can do is that u can restore the computer to the factory setting by reinstalling the operating system,without buying a new hard drive where u dont have to buy a new hard drive,u can reinstall the operating sytem with the help of the operating system disk or by going into the choices menu by pressing the f12 on the keyboard and then select the pc restore to the manufacturer's setting.and then hit enter and it will take near about 30-45 minutes and then u rcomputer will be like the first day u have received the computer u dont have to buy a new hard drive before replacing the hard drive pls try these steps.hope it will solve ur problem.thanks
Jan 20, 2009 | Computers & Internet
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
