Question about Kenmore 63942 Dryer
There is a clicking sound when you press start.
Kenmore 90 Plus Series
  • 147 Answers
If you heat a click when you push the button,but the drum doesnt turn your belt is broken. About $15 and simple to install.
Posted on Oct 23, 2008
Kenmore 90 plus series won't run unless I keep the start button pressed down. I found the thermal fuse blown, so I replaced it. This got the dryer to run again but not without the start switch depressed....
This is very likely a relay problem. There is a black relay in the control head that engages when the start button is pressed. The relays tend to go bad now and then. They are a simple replacement and cost less than $15 or so.
Sep 24, 2014 | Kenmore Dryers
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
check the door switch and also check the belt,if the belt breaks there is a switch inside that turns the dryer off
Mar 19, 2010 | Kenmore Dryers
90 series Kenmore washer won't spin
I have had this happen on a Kenmore in the past, and it was the motor coupling. It is a plastic part, and if it cracks your washer will not spin anymore. If you have the repair parts list, or can find it online, you will find the part I am referring to. Good luck.
Jun 03, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Kenmore 63942 Dryer Logo
125 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
