Question about Fisher and Paykel GWL11 Top Load Washer
GWL11 Burned Up?!?!
Noisy spin, burnt rubber smell, little water on floor then poof, no power to anything. Died on site. I've tried diagnosing according to Fisher paykel standards but can't figure out whether it's just the control board or the motor too.
    An expert who has written 2 tips or uploaded 1 video tip.
  • 22 Answers
Go and look at my issue on Eco Smart that won't drain.
Unplug washer. Bail out water as much as you can. Look for water dripping in black motor area. If you find that, read on to see if this is your issue.
You can take off black motor/white housing all in one piece. On mine, water was dripping from white plastic housing and onto motor. had small amt of water leak out, then wouldn't run at all and smelled like electrical issue. Look for white chip on upper rim of that white plastic housing where it attaches to machine bottom. Push in on clip, and give the whole white plastic thing a twist and it comes off--motor and white plastic. Unhook electric couplers.
You either have 120V or 240V (mine is older GWL10US model) unit. White plastic and black motor are one unit when ordered. Save yourself the service call that I paid. Good luck!
Posted on Oct 20, 2008
  • HiRoller Oct 20, 2008
    Should have said to tip washer back and look underneath. Black motor is on bottom of machine.
    Once you've removed that white plastic/black motor unit, look through hole into washer tub. I found one of my husband's socks in there and was able to pull it through the quarter-sized hole. I am guessing this is what started all of my troubles, a $65 service call and an expensive part!
I love my floor mate which I bought last year. Now it is making a funny sound and has a weird burning smell. I was told to take it to a repair shop but before spending the money I want to find out if this...
It may be the belt. Sometime the motor spins but the belt is not spinning with it. This causes the belt to heat-up and burn/melt. The burned rubber maybe what you're smelling and sometime make funny noise and hard to push the vacuum.
Oct 08, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
Spin cycle not removing all water - seems like it used to do a much better job. Used to achieve maximum spin speed faster than it does now and there is also a low growling noise at the beginning of the...
This is a belt drive machine, it takes more power to spin than to wash if the belt is worn it could spin slower, do you smell any belt russery burnt smell?
Sep 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
My Fisher and Paykel 5.0 is leaking brown stuff out the bottom and on to the floor, possibly oil. Where might it be coming from.
no oil in this machine , must rust with water , is it noisy on spin if it is get rid of it , will need a new outer bowl
Jan 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Burnt Rubber Smell
ok the rubber smell is your socks and underwear band,,and things with elastic in them ...ok open your dryer ,,look in the back where the hot air blows out,,,does it look like a burned iron..that where the clothe stick and melt too..just take a brillo with a little bit of water,,little dampness ans scrub the area..onthejob...
Feb 02, 2009 | Whirlpool LER7646E Dryer
Eco smart won't drain, smells hot
you commented on hearing water in the machine after the wash , i know that f&p spin bowls have a liquid inside the actual spin bowl system i think it aids in the spin operation of the machine, but if you had something in the drain network then that will stop the machine from emptingout as it all works on a time basis check and see that you are not getting any leaks from the bottom of the machime as your new pump won't last long if it gets wet also if there is water leaking that can be the main seal on the motor shaft failing
cheers grant
Oct 19, 2008 | Fisher and Paykel GWL11 Top Load Washer
GE Washer smells like burnt rubber
Hi, timhowarth1
ngafm at your service,
Because it wouldn't agitate or spin at all the belt burned as it tried to spin!
A problem with th coupler or transmission.
You need an experienced and hands on laundry tech or you may make matters worse or spend money replacing parts unnecessarily.
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You ngafm
Thank You
Sep 09, 2008 | Washing Machines
Maytag Model # LAT9635AAE
Check to see if it is a pump problem or a transmission problem. First remove both belts see if all the pullys turn freely. if the pump has a tight feel check inside pump for a item jammed in it.look for transmission oil on floor or belts if oil is present transmmision if probably going.ALSO check at the top of the tubs for anything stuk in between tubs.
Oct 10, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Fisher and Paykel Smart Drive burning mells
Oct 25, 2006 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
249 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
