Question about Cuisinart DLC-5 Food Processor
Safety-rod of bowl does not depress microswitch of Cuisinart processor
The interlock switch will not permit operation
  • 8,596 Answers
Cuisinart does not have the original pieces available, but you can order a replacement work bowl, lid, sleeve, etc that will work from the company. First do a motor test to make sure the motor is still working:
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Posted on Nov 25, 2008
My DLC-7 had the same issue. Since the unit is manufactured in Japan with parts from Japan, a failed part likely was not the issue. So I flipped the unit over and removed the dark colored base and then the micro switches (there are 2 of them) and cleaned the electrical contacts and their connectors with contact solvent spray as they had become dirty with the massive motor flinging around dust inside. Then on each switch I depressed the stainless steel micro switch actuator plate down and bent plate back a little so that the switch would actuate with less force applied. Lastly on the rear center switch I removed the rubber diaphragm and cleaned and applied silicon spray to keep it pliable. Then I reassembled the unit and all works just fine.
Note that to remove the base you need to lift up the outside corner of each rubber foot (use a putty knife or something wide to prevent tearing it) and insert a philips screwdriver into the hole and loosen the screw until it spins freely (on one of the feet the screw hole is located towards the center of the unit). There is no need to remove the rubber foot, besides the foot will keep the screw in place. Then start prying the base loose from the white or tan (depending on you model's color) top cover starting at the front where the toggle switches are. Mine was stuck from food debris buildup. Life off the base from the rear hinging it out.
Total repair time about one hour. Easy and worth it to elongate the life of this older robust unit.
Posted on Feb 03, 2010
Why Cuisinart mixer will not start?
All Cuisnarts have an interlock rod built in to the bowl assembly.
Make sure the bowl is positioned on the motor base correctly, and the actuator in the lid that pushes the interlock rod down is not bromen or damaged. If it is intact and working correctly, then check the switch it pushes on, or the main power switch.
May 20, 2014 | Cuisinart DFP-11 Deluxe Food Processor
The bowl on my cuisinart food processor is locked in place. How can I unlock it to remove the bowl?
You don't say what model, but all Cuisinarts have a safety interlock built in to the bowl assembly. The cover must be removed from the bowl to release this interlock before you can remove the bowl from the motor base.
Apr 20, 2014 | Cuisinart Food Processors
I can't get it to work and can't find the manuals anywhere.
Often the problem when these will not run is that the safety switch is not being closed. Often rotating the cover will cause a prong to depress a rod thaat actuates the safety switch. Explore the unit to look for such an interlock. I can almost guarantee that it is there someplace. Occasionally the prong that actuates it gets broken or worn.
Dec 22, 2009 | Kenmore 219103 Food Processor
Won't start
Make sure the work bowl handle is locked in place so that it is facing the front of the processor (same side as the on and off switches).
Make sure the feed tube of the lid is facing toward the back of the processor and that the plastic or metal rod of the pusher sleeve is facing the back of the processor.
Note: this assembly only applies to the Cuisinart DFP-14 series - every Cuisinart has a slightly different assembly for it to turn on.
Sep 13, 2009 | Cuisinart DFP-14BC Custom Food Processor
Cuisinart prep 11 Plus won't run.
Remove the work bowl completely and separate the work bowl, lid and pusher sleeve. Plug the base into the wall outlet and press the on switch. Use a pen to depress the dark grey or black button on top of the base of the processor. If you don't hear a sound, then call Cuisinart and get it repaired. If you do hear a sound:
1. Put the work bowl on first, making sure the handle is facing front
2. Put the lid on, making sure the hollow feed tube is facing the back of the food processor
3. Put the pusher sleeve in, making sure the sliding lock switch faces toward the front of the processor
Turn the machine on - it should now be working
-Tha Mp3 Doctor
Dec 24, 2008 | Cuisinart DLC-2 Mini Prep Plus Food...
Motor switch not activating on a dfp-14ts
Is the cover assembly engaged and locked into place? If you can't lock the cover into place, it's possible that part of the plastic on the cover assembly is broken and not engaging the white rod inside the bowl. Determine which part is at fault (either the bowl or the cover assembly) and replace it.
Dec 19, 2008 | Cuisinart DFP-14BC Custom Food Processor
Often it is difficult to unlock the bowl on the cuisinart food processor
Have you tried removing the lid first? Mine has an interlock where I have to remote the lid before I can unlock the bowl from the machine. Good luck!
Sep 20, 2008 | Cuisinart DLC-5 Food Processor
I cannot get my processor to start
Food processors are notorious for having safety interlocks. If everything - and I mean everything - isn't attached in the correct sequence and clicked into place, one of the safety switches may not be engaged.
You can test it by switching back to the setup you used before to see if it will still operate. If so, then CAREFULLY review all the steps needed to use the new setup.
Mar 12, 2008 | Cuisinart DFP-14BC Custom Food Processor
Cuisinart DLC-5 Food Processor Logo
587 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
