Question about Neff U1661 Double circotherm super Electric Oven
Neff oven door (U1661)
The bottom door of the oven does not close fully and therefore the heat just escapes?
  • 1 more comment
  • longtongue10 Oct 20, 2008
    Thanks for the help,now i have to find a source of spares which dont rip you off with exhorbitant prices.
  • Anonymous Oct 27, 2008
    Hi I have just moved into a house with a U1661 only 3 years old and the bottom door has exactly the same problem
  • Anonymous Mar 25, 2014
    Door does not close tightly
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Posted on Oct 20, 2008
How do you take the doors off Neff double oven
fully open door and lift up small metal stirrups on bottom of hinge then close door up to them grip door firmly and lift upwards ,there are videos on you tube for this also.
Feb 09, 2017 | Neff Ovens
Tip
Common heating faults with Neff U1661 Double oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1661 Double circotherm super...
I have had both door hinges replaced on the main oven of my Neff but the door still does not close properly. What is the next step?
I would have gone straight through Neff. If it can't be fixed, your'e supposed to get a new oven out of the deal.
Apr 29, 2012 | Neff U1461 Double circotherm plus Electric...
How to replace knobs on u1661 oven
Just pull them off and replace. Its that simple.
Apr 27, 2012 | Neff U1661 Double circotherm super...
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
NEFF oven U1461 - The bottom oven door hinges do not have enough strength to hold the door fully closed. Can these be adjusted and is this something I could do myself?
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Thanks.
Nov 05, 2009 | Neff U1461 Double circotherm plus Electric...
Neff U1661 main element doesn't heat up
Hi.
Yes ,it is the element.
You need to remove the panel at the rear of the oven, this will give you access to the element.
Good luck
Nov 21, 2008 | Neff U1661 Double circotherm super...
Neff oven u1420
Hinges not fitted properly,or possibly wrong hinges
Nov 03, 2008 | Neff U1661 Double circotherm super...
Change Bulbs in Neff U1661 Oven
You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
Bulbs available from Homebase, Wickes, BandQ etc etc.
Apr 27, 2008 | Neff U1661 Double circotherm super...
Neff U1661 Double circotherm super Electric Oven Logo
621 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
