Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Loud Pop Vizio P50HDTV10A 50 in.
My Vizio P50HDTV10A 50 in. had a loud pop, then the picture turned black, audio still working. What is the fix? Will you help me?
THANKS! Chris My three year old vizio poped, the picture dimmed, popped again a couple of minutes later and the picture went completely away. Is there somebody out there who tried replacing the z board, y board, and y support boards? Did it work? From the two pops, I suspect two different things blew. I've read many postings of the problem, but haven't seen a posting from someone who solved the problem. Help?
  • 4,889 Answers
Just to add to the above post it can also be popped Ceramic fuses. Its worth a try. In most sets I fixed there are about 6 of them and cost you about 10$. Check the specs on the fuses and get the same ones. Pop the old ones out and the new ones in and see if it works.. If it doesn't you have to get a new PS board as WeListen2You has suggested.
Posted on Oct 20, 2008
    Master:
  • 538 Answers
Sounds like the power supply board..could be the system board, but sounds more like the power supply board..this unit still under warranty?
  • A Womans Computer Man
    A Womans Computer Man Oct 20, 2008
    i used to fix these when I lived in Hawaii, and it takes some doing..first thing you can do, is take off all the screws, something like 35 of them, and inspect the board area, after removing all the covering..wait around 15 minutes for any residual energy to dissipate..and, use a wrist strap for ESD, if you get creative here..
P50 sound ok picture went dark but not out all the way. Made a loud noise when it happened
did you ever get a answer?
i also have a p50hdtv with a black flickering screen
but no pop and sound is still working.
May 10, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A TV went pop now has a black picture
Don't know which boards Z or Y have dead capacitors pop open,take ur tv aparts check boards that have pop opens parts or burn marks on them.Replaced that board will solved ur problems.Tries Shopjimmy.com,Ebay.com to buy refurbish boards for the replacement.
Mar 22, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
TV won't stay on. When turned on it will pop real
No longer require your help. Have called service repair.
Dec 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
4-year-old 50-inch flat screen made a loud 'bang' and picture went out. The noise was more mechanical than the type of pop or snap you'd expect if a capacitor blew. The audio is still ok.
Depends on the physical size of the cap; there are some larger ones in your set that would produce a 'bang' but you should also have gotten a whiff of the airborne chemicals then.
Sep 01, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Loud pop, smoke and screen went dead
Your mainboard is damaged, just replace it and that will fix it.
Jul 01, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Screen is black, audio is fine. TV is 2 yrs old.
Y SUS all the way.download the service manual to obtain part # and location of this board in the back check out the exploded view.
Jan 27, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Had loud pop and then no picture on the vizio 50in. plasma
TV was on with no picture problem. Left the room and when I returned the picture was very dim. Turned system off and turned back on. Picture didn't change, but heard a loud pop from the back of the TV.
Mar 25, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
545 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
