Question about Coleman Sport & Outdoor - Others
Scanoe, Ram-X, Split in hull near gunwhales- Repair, How?
4-5inch splits in hull material at gunwhale level adjacent to the seat mounts (it's the older Alluminium construction 'frame') . Foam patch internally keeps water out temporarily but need permanent repair..
I found a Scanoe like this on craigslist that was being given away because of several splits ins the hull. I was ready to buy that patch kit on line when I stumbled on a solution that worked great! I was in Home Depot looking in their pond department and saw some self adhesive patches for poly ponds. I bought on for less than $7.00 and gave it a try. I sanded the inside of the hull around the split. cleaned it well and applied the patch. It worked like a charm!
Posted on Jul 01, 2009
    Problem Solver:
  • 12 Answers
Hey I had the same problem with my old coleman. I found a web site selling a patch kit, I used it a couple of years ago. The site was Bullseyetradingpost.com I think. Hope this helps.
D. luftkin
Posted on Feb 22, 2009
Land rover lr 3 key padwill not unlock doors battery is charged
There is a splice joint under the passenger side sill plate, under the second plate, about adjacent to the right front seat mounting. Split the harness open. Look for a blue tape with three thin green with white stripe wires. Open the tape. The joint is corroded and broken apart. This feeds the alarm rf receiver. Fix the splice and your remotes will work. - Kyle L.
Jan 07, 2013 | 2005 Land Rover LR3
I can't find any id on my old scanoe, how can i get an id number for it.
I have one from the 1980's and found numbers stamped on the side stern quarter, hard to see
Mar 21, 2011 | Coleman Boating
Can i change my single seat to split seat
Yes check craiglsit or ebay you need to purchase the seats the plastics and the seat subframe.
Jul 25, 2010 | 1999 Honda CBR 600 F(4)X
I have vertical cracks at the location of the seat attachment. why did it split at this point and how can i repair it ? it is a coleman scanoe .
It cracked at the seat bracing starting at the screw holes due to expansion and contraction of the plastic polyethylene. The heating and cooling effect is caused by storing it outside or worse directly in the sun. Go to www.bullseyetradingpost.com they have a simple fix for this, you should be back in the water in short order,then store it out of the sun.
Nov 27, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Require specifications for an Emailair split level air con model CWS 034A
Capacity which normaly known as Horse Power
or RA rating
The voltage input
Ampere ratings
voltage phase ex. (single phase or three phase)
Type: Split type
since it is split type there are several classification(wall mounted, foor mounted or ceiling mounted)
Oct 31, 2009 | Heating & Cooling
How to remove/replace spark plug wire routing clip for 1,3,5 cylinders (front of engine) of 1989 Buick Century V6 3300?
Typically, spark wires are encased in a flexible plastic tube which is secured in usually 2 places with special clips. The tubing material gets brittle over time and cracks /breaks easily so patience and being careful are the key. After you remove the tube from its mounting points, you will notice that the tube has a split over its entire length. Carefully spread the split open at on end then pull (one wire at a time through the split. then reverse the process with the new wires..... unfortunately this is even more difficult and requires even more patience... good luck....
Oct 17, 2009 | 1989 Buick Century
How to remove rear seat in 1996 dodge ram 1500
REMOVAL & INSTALLATION
  1. Clamp the seat belts to keep them from retracting.
  2. Locate and disconnect seat wiring at the connector(s).
  3. Move front seats forward or back for access to the hold down hardware.
  4. Put the rear seats in the stowed position.
  5. On Durango 3rd row seats, lift the cushion upward and forward to floor cargo position.
  6. Remove the hardware securing the seat.
  7. On split bench models, lift the center seat upward to clear attachment stud
  8. Remove the seat from the vehicle.
NOTE Do NOT activate the track adjusters once the fastening hardware is removed.
  1. Installation is the reverse of removal.
Fig. Disconnect the wiring from under the seat
Fig. Seat track mounting hardware locations-typical
Fig. Bench seat components: seat (1), nut (2), stud (3), floor pan (4), bolt (5)-Ram
Fig. Split bench seat assembly-Ram
Fig. Bucket seat mounting components-Durango shown
Fig. Rear seat removal/installation
I hope help you with this; good luck (rated this help).
Aug 31, 2009 | 1996 Dodge Ram 1500 Club Cab
Split hull
V out the cracks with a grinder, cut fiberglass matting with an overlap of about half an inch. pre-cut 6 more pieces gradually stepping overlap to 1 1/2 inch starting with smallest piece soak in resin and place over v'd out crack, once all pieces are in place press out any air bubbles. takes a while to dry. once dry sand flat with 36 grit then 80 and 150. place a gelcoat on top
Jun 01, 2009 | Boating
Sport & Outdoor - Others Logo
1,801 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
