Wharfedale tv key code
When i switch my tv on it just says (Key - - - ). I need to know what i am meant to enter in the dashes. I would be so grateful if anyone could help me. key code to wharfedale M2126
  • 525 Answers
I think that this can be a parental control key. if you don't have the key , you can find in owner manual the key which you can use . and if you don't have this manual you can probably try any combinations from 0000 to 9999.
And after all call the company and they will help you .
Posted on Oct 20, 2008
  • bob robinson Jan 31, 2012
    most probably it mite still be on the mskers code usaly set with all zeros,good luck
I've lock my tv how to
Posted on Oct 16, 2012
  • hammer09953
    hammer09953 Oct 16, 2012
    i've lock my tv how to
I need to reset my sharp tv. It has a password on it and I cannot use the tv
You've to enter its service mode to reset it.
1. Service mode is switched by SERVICE key, CH UP + VOL DOWN when reset.
2. Service mode is cancelled by SERVICE key during Service mode.
3. Service mode can be switched to the following 5 modes via MENU key:
Do it with care. Enter the site linked here to know more. Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name first.
Dec 20, 2012 | Televison & Video
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
Sep 25, 2012 | Apex Digital Televison & Video
Wharfedale 21in tv blue screen with the word key in top corner with 3 dashes please help
You have accidentally activated the system lock or parental lock. This usually happens when 2 buttons are pressed on the remote simultaneously.
You will need to enter a PIN number using the numerical keys on your remote. If you have set a PIN number for this TV you will need to enter this. If not, you will need to enter the manufacturer's default PIN number. This is usually a simple combination such as 000, 111, 222, 123, etc,
I can't tell you the exact PIN number without knowing the model number of the TV. Please try the simple number combinations shown above and post back with the model number if you need further assistance. The model number can usually be found on a sticker on the rear of the TV.
Regards,
BElectric
Jan 10, 2011 | Televison & Video
Need code for tv remote to operate tv by the remote
Hello
You cannot change Parental
Control settings without
knowing the secret code. If
your code changes, someone
else has altered it and possibly
viewed blocked channels. Yet try the following procedure:-
Philips sets uses a four digit code to contro the V-Chip. The override code for Philips set is " 0711 "
although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Dec 28, 2010 | Philips Magnavox 27MS343S 27" TV
My wharfedale tv comes up with key --- how can i
click channel 1000 if you have flow instead ok
Jul 14, 2010 | Televison & Video
I have accidentally turned the child lock on and then turned of the tv and when i switch it back on it comes up locked on the screen and none of the buttons respond and i do not have the remote controll...
Get a Magnavox (or Philips, same company) brand universal remote and try this. I found this info at a tech website, but I haven't tried it myself (never have used parental lock on any set), so I don't know if really a solution.
Philips sets use 0711 as the override code to defeat parent lock. You may need to enter the code twice if it says "invalid code" the first time.
Using the remote control:
Press the MENU key. Scroll up or down until you reach AUTOLOCK or SMARTLOCK. Press the "right arrow" key. Enter code 0711. Enter it again if it says invalid code.
Once in the AUTOLOCK or SMARTLOCK menu:
Scroll to BLOCK. Press the "right arrow" key. Scroll to BLOCKING OPTIONS. Press the "right arrow" key. Scroll to MASTER DISABLE. Press the "right arrow" key. This should unlock the parental control.
Hope this works for you. Thanks for using Fixya!
Mar 12, 2010 | Philips 28PW6305 28" TV
Wharfedale key code
Ur tv is lock could be letters or numbers or anythings.Ask the last owner for the codes.Try unplug it for awhile then replug the power,that all u could do.Codes to reset old tv might not exit anymore.
Oct 22, 2009 | Televison & Video
Want user manual
here is a link to your manual
http://support.rca.com/doc/Device_Documents/manuals/RCR311B_manual.pdf
the codes for a sansui tv are:
Code For Model RCR311B
Code 1191 for Sansui TV Code 1247 for Sansui TV
instructions:
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box).
2.Press and hold the TV key. The illuminated ON•OFF key turns on andremains on. If you release the component key at any time during theDirect Code Entry procedure, the illuminated ON•OFF key blinks fourtimes, and the process is exited.
3. While holding down the TV key,use the number keys (0-9) on the keypad to enter the first code above.While you are pressing the numbers, the illuminated ON•OFF key turnsoff.
4. After the fourth number is entered, the illuminated ON•OFFkey turns on. At this time, release the TV key. If the illuminatedON•OFF key turns off, you have entered a valid code and have followedthe correct procedure for Direct Code Entry. If you enter a code numberthat is not in the Code Lists or you do not follow all of the steps forDirect Code Entry, the illuminated ON•OFF key blinks four times whenthe TV key is released. This is an indication that a programming errorhas occurred. In that case, repeat the Direct Code Entry process fromstep 2 and try the next code listed.
5. To confirm that thecomponent key is programmed with the correct code for maximumfunctionality, test the component. Attempt to control a variety of thecomponent’s functions with the remote. If some of the features of yourcomponents do not work, try programming the remote with a differentcode in the list until you find the code that allows the remote tocontrol the majority of your component’s functions. Different codes canprovide different levels of functionality.
7. Remember to write the code down for future reference
Sep 05, 2008 | Sansui Televison & Video
First try just 0000. That is the default codes for most TVs. If the box is from a cable or satellite company try the last four of your social security number or account number.
Jul 11, 2008 | Televison & Video
Televison & Video Logo
235 people viewed this question
Top Televison & Video Experts
Electro Med Services...
