Question about Vapor T 2200S LadyBug Canister Steam Vacuum
T2100 S Ladybug Canister Steam Cleaner
I've lost my manual. How do you "clean" the machine. I've emptied the water from the top of the machine and also taken the bolt off the bottom and emptied the liquid out of the machine. Is there an on-line instruction manual available? Thank you for any help you can provide.
  • cmitchell837 Dec 08, 2008
    I need a manual for the ladybug steam cleaner as well.
Visit the Ladybug Ladybug 2200S Vapor Steam Cleaner page and scroll to the bottom. There's a link that says, "Download owners manual."
Posted on Dec 16, 2008
Need a water tank safety cap for euro- pro canister steam cleaner model S3325H
I need a cap which is located on the back of the clean water tank on a Bissell model 1950-3 steam cleaner
Aug 20, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
Suds not coming out
do you have the dial set to presoak ? Clean? or Rinse?
make sure the container for the soap is full and is popped into place correctly.
also... if the water canister is empty or the dirty water container is full it will stop sucking up the water :)
Mar 29, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have a billell Pro Heat 2X without a manual. How do I fill it and what ratio water to cleaner?
The cleaner goes into the small bottom at the very rear of the machine. It is uses full strenght (don't add any water to it). You add clean water into the bottom clear plastic section on the front of the machine. The clean water bladder is soft plastic and it is filled from the top. When you start using the machine, the dirty water will get suctioned into the section surrounding this bladder. The machine will stop working when either the bladder is empty or the dirty water section is full. Remove the entire plastic section to dump out the dirty water.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Eureka Atlantis 2590 Deep Steam Extractor will not spray
I cannot find a shampoo canister for my Eureka 2590 Series extractor. They are not made anymore.
Jun 07, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Polti Vaporettto 3000 Steam cleaner
I suggest using KalStop to remove the calcium and minerals built up in the machine. Polti has built the machines to stop working when there is too much calcium in the boiler to prevent further damage.
Aug 24, 2008 | Polti Eco Pro 3000 Canister Steam Vacuum
Steam cleaner
Most upright steam cleaners like Hoover and Bissell, you put in the hot water, bissell does have a heater, but it only helps get the hot water a alittle hotter. But a model number would help.
Dec 12, 2007 | Vapor PC2200 Ladybug Steam Vacuum
Vapor T 2200S LadyBug Canister Steam Vacuum Logo
393 people viewed this question
Top Vapor Vacuums Experts
richie46
ray gallant
Tom Chichester
Are you a Vapor Vacuum Expert? Answer questions, earn points and help others
