Insignia TV Powersupply
Hey, I am a student and I need to replace my power supply in my parents Insignia tv. I was wondering where you order the power supplies from and roughly how much they cost. Thanks in advance.
Ryan Ramplin
  • ramplinr Oct 20, 2008
    I am fairly well with electronics and such for repairing, reading schematics and building them once I am given a schematic. However, I am not very good a diagnosing problems. I am wondering if you know what the problem with the power supply usually is.
    The TV will turn on occasionally but will power off after sometime (a different amount of time always) also sometimes the when it is plugged in and the main power is on the light won't be red and definitely won't turn blue once the other power button is pressed. When I read voltages it's reading 121.8 at the input and around 85 at the power supply. Do you know other places I should test or if it is just a component on the power supply that fails and if that is case there is a good chance I have that component around here (where I work) and can replaces just that. Thank you again in advance.
    Ryan Ramplin
  • 2,326 Answers
Click here to find parts for your LCD. I can also repair your power supply.
You can write an email to for more info.
Posted on Oct 20, 2008
  • Jaime Hernandez Oct 20, 2008
    I would suggest to visually inspect the electrolytic capacitors for bulging and leaky conditions or if you have a capacitance meter to remove them and test them outside the circuitry. The capacitors failure is very common on LCDs power supplies older then 12-18 months.
Insignia tv, will not power on. no lights are on
Try using a different room. The sockets will probably be on a different circuit. If that doesn't work, it sounds like a power supply problem on the TV. You'll need to replace the part. Unfortunately, it's usually cheaper to buy a new Insignia tv than getting the power supply replaced. TV technicians are expensive
Feb 15, 2014 | Televison & Video
Insignia quit working after storm
Check the fuses on the power supply board first. They usually blow when you get a power surge. You may be able to replace them and get the TV running for a few dollars. If the fuses are good then the power supply board will be the issue. The main board should not be damaged because the surge has to go through the power supply board first.
Aug 22, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
Plugged in no power light or picture cord checks out good
replace power supply. multiple components died on power supply to many to replace and some to small for hand solder. cause cheaply made power supply
Apr 27, 2010 | Insignia NS-LCD19 19 in. LCD TV
I need a Power Supply For Insignia TV Model NS-LTDVD26 and Part Number DTV2600.PCB How Much
You can order parts for your TV here. Select your exact model for available parts.
Sep 27, 2009 | Insignia NSLTDVD26 LCD TV
RCA TV Model F32444 Will not power on
The noise you are hearing is probably the degauss (it demagnetises the screen every startup). The most likely problem is the power supply. Do a replacement of all the caps on the powersupply board and it will likely fix your problem. Because it still has power to the degauss coils it hasn't blown the fuse. Power supply not starting like that is usually caused by a small electrolytic capacitor near the heatsink on the mains side of the powersupply. They can be replaced for about 10 cents.
Hope this helps
Feb 14, 2009 | RCA F32444 32" TV
TV sparks inside case
there will be a problem in powersupply.and ity is best to be checked by the technician in order to see the deffective parts..
Aug 16, 2008 | RCA 32V550T 32" TV
Insignia IS-LCD TV 26 Will not turn on
The power supply will need to be replace or repair if the LCD failed to switch to the blue light.
I repair these power supplies.
Let me know if you need further assistance.
Jun 12, 2008 | Insignia LCDTV26 26 in. Television
Televison & Video Logo
657 people viewed this question
Top Televison & Video Experts
