Help me fix acer 5310 notebook power subsystem
Hello, Please help me with my acer aspire 5310 laptop. I mistakenly connected a printer adapter to it, so it got spoilt. It does not power on, even when I remove the battery and use only the adapter. I guess the problem is with the mainboard. Can you tell me how to find the IC or other components I may need to change on the board. Or what else should I do. Thanks
Acer aspire 3004 battery not charging
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Oct 02, 2011 | Acer Aspire 3004WLCi Notebook
Acer aspire one battery problem
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Hope this helps.
Feb 23, 2011 | Acer Aspire One PC Notebook
REPLACED POWER JACK.POWER LIGHT COMES ON ,BATTERY CHARGES,BUT NO BIOS OR SCREEN ACTIVITY. ACER 9300
hello,
probably when the power jack was being changed, a connector cables was mistakenly tampered with,
therefore in order to fix this, try to unscrew the laptop, check all available cable that makes a connection. once you sight the cable that was tampered with, connect it back to its normal place, screw thelaptop back together then turn it on.
Jan 02, 2010 | Acer Aspire 9300-3716 Notebook
HP Printer Usb port in my Acer Laptop , shortcircuits my house
hello
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
TekSpotDotCoDotUK
Aug 26, 2009 | Acer Aspire 6930-6941 Notebook
Sound driver lost
Head over to this website:
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com/canada&siteid=7297&areaid=17&formid=3394&LINKTEXT=Drivers%20%26%20Downloads
This is Acer's office driver download section. You can also get there by going to Acer.com and clicking Support. Then select your product and find the correct driver.
Nov 27, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire wlan driver problem
Please visit the below mentioned link to download Windows XP drivers for your laptop:
Acer Aspire 5220 drivers for Windows XP
Thank You
Nov 14, 2008 | Acer InviLink 802.11b (91.49C10.002)...
How can I repair my acer 5310 power system
You problably burned it. The printer works with 30 volt current, and the laptop works at 18 volt.
If there is a floppy drive, remove it and try to boot.
Best of luck.
Oct 04, 2008 | Intel Motherboard
How to turn on wireless on Acer Aspire 4520 laptop
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Sep 04, 2008 | Computers & Internet
Regarding drivers of acer aspire 5310 laptop
Hi - You can download the software from the link below:
Aspire 5310
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 05, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
David Payne
David Payne
