Question about V, Inc. Vizio L13 LCD Television
Remove back of Vizio tv
My cable connection has slipped into TV case so I cannot connect cable from wall. How do I take off back of tv to reinstall cable connector?
Thank you
  • billc7 Jan 13, 2009
    My cable connector has snapped off and I also need to know how to remove the back of the L13.
Vizio Model E470VL, HDMI ports are not functioning properly.
on some TV's the Analog board is where the other cables plug into. I know on a Sanyo I am working it looks like the analog and main digital board are all the same. but they are just hooked together. I bought an analog board for less that $30 from Shop Jimmy.com. The prices might vary according to the make and model of TV. need to be careful and remove the back of the TV . and get the part # directly off the board. BE SURE TO UNPLUG from the wall outlet first. Nearly all the boards carry a charge even when unplugged so be careful.
Nov 18, 2014 | Vizio E470VL 47 in. HD-Ready LCD TV
42" Vizio 240Hz SV421XVT no hdmi video or audio
Possible bad source, bad cable or connection was made with units powered up which HDMI does not like.
First thing to try in this case is to remove power from set and whatever unit is connected via HDMI and disconnect the cable itself.
Wait for several minutes, connect HDMI again and THEN return power to the units that were removed from power, this cannot hurt and may help or correct this issue.
Failing this try if possible to connect using component connections.
Dec 10, 2012 | Vizio SV421XVT 42 in. LCD TV
MMy Vizio 32" tv only gets 16 channels
If your Vizio TV has a built-in HD converter, 16 channels is what you can expect. If the channels are identified with decimals such as 10.1, 10.2, etc. they are HD. The cable connection you refer to must be connected to an antenna, otherwise you would have a cable box and a monthly bill from some cable company
Dec 04, 2012 | Vizio E322VL 32 in. LCD TV
My Vizio VBR-100 Blu-Ray Turns on once connected to the wall outlet, but does nothing else like showing any thing on the tv input. Why?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 21, 2017 | Vizio VBR100 Blu-ray/HD DVD Player
Where is my cable output on my Philips TV 32PF7321D/37. How do I get cable on my TV I cannot find a cable output! please help
your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
Mar 10, 2011 | Philips 32PF7421D 32 in. LCD HDTV
Red vertical line on the screen due to external shock
This is most likely caused by the cable on the T-CON board being bent out of place by the shock.
If you know how to work on electronics or have a friend with knowledge/skill you can fix it.
DO THIS ONLY IF YOU KNOW HOW TO WORK WITH ELECTRONIC EQUIPMENT.
REMOVE THE PLUG FROM THE WALL. REMOVE INPUT signal cable from set.
REMOVE THE POWER CABLE FROM THE SET.
>Lay the set down on a flat cloth covered surface.
>Remove the back cover.
>Remove the shield covering T-CON board. This small board is located in the center near the top.
>Move the cable(s) connected to the T-CON around.
> Set the tv upright and make sure it is stable.
DO NOT TOUCH ANYTHING ON THE BACK
ATTACH INPUT SIGNAL cable to set.
ATTACH THE POWER CORD TO THE SET.
PLUG THE POWER CORD INTO THE WALL.
>Use the remote to turn the set on. If the vertical lines are gone, THEN TURN the set OFF.
REMOVE THE POWER CORD FROM THE SET. Remove signal cable.
> Lay tv back down on table.
CAREFULLY REPLACE THE SHIELD over the T-CON.
Replace the back cover etc.
Now you can reconnect the input cable and power cord.
SOMETIMES THE IMAGES can get worst and you have to repeat moving the cable around. In the worst case you can dis-connect and re-connect the flat cable WITH THE SET UNPLUGGED.
I believe the T-CON may sometimes be called LVDS and look similar to;
Feb 15, 2011 | Sharp Aquos LC52XD1E 52 in. HDTV-Ready LCD...
Have vizio tv trying to hook audio out puts of tv/dish network for component usei nto my stereo receiver what do i do
The easiest way to connect this is to find the cable going from the receiver to the TV and disconnect it from the TV.
Connect this cable to the back of the stereo receiver where it says "in" or "input".
Next take another cable and connect it from the stereo receiver output to the TV.
Daniel Busa
DISH Network Customer Service
Feb 06, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
The Netflix app on my vizio svt422xvt (one of the Vizios with VIA internet & wifi built-in) won't connect to Netflix. It directs me to the Netflix website for help, but Netflix help tells me to...
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
Aug 11, 2010 | Televison & Video
Connecting the cable coaxial cable to a P50HDM VIZIO TV
yea wtf same prob here just want to put a indoor antenna now I got to go buy an external receiver booooooo!
Jan 10, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
V, Inc. Vizio L13 LCD Television Logo
965 people viewed this question
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
