Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side Model #TFH24PRSMWW Ice maker
The ice maker works. Except when the switch is on the cube selection it delivers crushed ice sn a very little water. I removed the ice holder tray and looked up underneath saw that the little flap was closed so the cubes could not fall. I could keep the flap open when I rotated the arm. I could not put the tra back with the arm in the correct position. I also tried moving the switch a couple of times from water to the cube delivery to se if that worked. I also removed all the ice from the tray and put alittle back in to test and it still delivered crushed ice when in the cube position.
The on and off switch of the ice maker on the ge side by side model has fell off and appears broken. please instruct with a diagram how to reattach.
Posted on Jun 17, 2009
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Our GE Adora Refrigerator's ice maker isn't working properly
Perhaps your freezer isn't set cold enough - or your freezer door seal is not sealing correctly and the ice cubes are melting in the bin and sticking to one another and the spiral screw that delivers the ice.
Mar 14, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker only makes crushed ice, no cubes
The button which selects cubes versus crushed controls a solenoid which engages/disengages the crusher. If the mechanisms which crush and push the ice from the chute are all clean, free of ice, etc., then the solenoid is not working. It either has loose/dirty connections or the solelnoid is bad.
May 05, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
443 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
