Question about Tricity Bendix WDR1240W Front Load Washer / Dryer
Water just keeps running /won't fill
Turn on machine and the water just runs thru and doesn't fill the machine. Is there a shut off valve not working. Where do I get a Part number for the part?
  • floydandriky Oct 20, 2008
    the unit is built into a rv so I never looked behind the thing, but I bet you are right. the camper is in storage for the year but in the spring the first thing I'll look at is if that pipe fell over behind the washer. Thanks. Two heads are always better than one(even if one is a cabbage head) that being me. thanks for the help.
  • 135 Answers
This is an easy one. the waste pipe is two low!!
Posted on Oct 20, 2008
Water flows constantly during the spin cycle
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced.
Dec 08, 2011 | GE WBVH6240F Front Load Washer
Water keeps running, toilet not shutting off totally, tank will fill then we have to pull up float and hold it a while to stop water, doesn't overflow, just keeps running, doesn't shut off...
Hi snowjobs847...
Try resetting your float level to a lower water level in the tank, the extra pressure put on the seal may make it reseal.
If the above did not work:
You need to replace your "ballcock"...the ballcock (inlet valve) is non-repairable, has to be replaced with a new one if you cannot get it to stop leaking.
Please take time to rate me
Sep 04, 2011 | Home
My daughters TOTO toilet kepted running so she turned off the supply line before she went to bed. when she woke up the next moring and turned the water back on, now the tank won't refill. How do I know...
There could be several reasons why it won't refill. It could be the fill valve, which can be replaced with a standard fill valve located at any hardware store. The more likely reason is the stem inside the shut-off of the toilet has broken off inside the valve. This is very common when a valve is older and usually doesn't get shutoff. If this is the case, a new shut-off valve must be soldered on.
Aug 29, 2011 | Toto CST743S Drake Round Toilet
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
We can only use hot water in our Whirlpool 7.5kg WFE1070BD 1000RPM - how to we shut off the hot water and use cold water? We have tried only cold but the machine will not operate. Please help. Many...
Turn off the water to the machine. Disconnect the cold water hose from the back of the machine and put it in a large bucket. Turn on the water to see if you get full-pressure cold water from the hose. If not, the shut-off valve or other plumbing has a problem.
If you do get cold water from the hose, check the strainer inside the hose fitting on the back of the washer. Clean it if it is clogged. If you still don't get cold water in the machine, you have a problem with either the solenoid valve or the cold water fill contacts in the timer (the timer won't start until the tub is up to the selected level, but if the valve isn't opening or the supply line is otherwise blocked, the machine will never fill). Sometimes in this case you can hear the solenoid valve humming (normally the sound is masked by the running water).
If the problem is a clogged strainer, clean out the hot water strainer also.
I find I get better wash results with warm water (runs both hot and cold for the wash cycle). The soap is more active than in cold water, so I don't need quite so much, and the machine doesn't take as long to finish a cycle since it fills faster. Of course, the cold water has to be running to get the energy savings compared to hot only.
Jun 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Water want cut off keeps running and filling up with water
Pressure sensing tube obstructed. Remove water from machine. Find the tubing and remove it from the water level switch so yall can blow it out. Reconnect the tubing and party on!
May 16, 2011 | Washing Machines
If I choose to have the water full to either large or even a medium level. It keeps feeling up and won't turn off. keeps running water. Why?
If water won't shut off even if you unplug the washer, then the water valve is likely stuck and will need to be replaced. If the water shuts off when water level switch is on low, but overflows when set on medium or high, it is more often the water level switch itself. Before replacing, be sure the tube going to the side of the tub is clear and not kinked. Remove the tube from the switch and blow thru it, reattach and try filling again. If it works, you should be ok, if not then replace water level switch.
Jan 18, 2011 | Whirlpool Washing Machines
Water doesn't come down when brewing
I had the same problem, and it turned out it was the top needle that was clogged. I used a safety pin to clean out the needle and it worked again . . . I descaled immediately, just in case it needed that too. I am back to coffee goodness!
Jul 07, 2010 | Keurig B60 Coffee Maker
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Machine won't fill with water
Check that the inlet screens on the water supply are not clogged.
Make sure the water is for certain turned on (assuring nothing has changed).
If those are not found to be the problem, then it could be the fill valve(s) or the timer control.
Reply back what you find, and I can help you further.
Jan 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
Tricity Bendix WDR1240W Front Load Washer / Dryer Logo
166 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
