Question about Microsoft Likom HD19A 19" LCD Monitor
Monitor Start up
I have aLikom HD19A LCD monitor. The problem is when the pc first boots up the power light would stay on standby until you power off and pwer on the monitor. The light turns Green until Windows boots up and I get the No video signal window. I power off and power on the monitor and the light turns grenn and I got signal.. The monitor worked normaly when I first install it. I've tried a different videocard and check the bios settings and the monitor still has the problem
  • vgornov01 Aug 01, 2008
It is the same problem I experienced and now it suddenly stopped and dead.
what the manufacturer of the unit has to say about inherent design fault which they are liable under UK consumer law to rectify within 6 years
And incidently who are manufacturer to this Licon make is please
Posted on Jun 23, 2008
Is my computer in standby mode?
Make sure you have the cable that plugs into the back of the computer from the monitor screwed in tight. Also make sure the cable on the back of the monitor is screwed in tight and also that the power cord on the back of the monitor is pushed in all the way.
I'm almost certain you're not in standby mode. Does the computer stay on when you get the no signal message? Do you hear the fan blowing, do you hear the disk drive spinning? If not, I think your system has completely shut down. I'm thinking maybe a virus or some hardware/software conflict is stopping it from completing the boot cycle.
Try getting into the Bios or System Setup to see if the LCD Stays on and the computer stays on. Turn the computer off, then hit the power button to turn it back on. Look at the lcd screen and it will tell you what key to hit to go into the Bios or System Setup. Go into it and let the computer sit for 10 minutes or so to see if it shuts itself off.
If you are successful with the computer staying in the Bios or System Setup lets try getting into Safe Mode and see what happens. Turn the computer off and hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see the SAFE MODE option. Select the Safe Mode option and let the system boot up. Safe mode will look different to you. The icons will be bigger and the lcd screen darker, but that's normal. If you are able to see the desktop in safe mode just try opening up MS Word and maybe let it sit for a few minutes to see if it shuts off.
If safe mode was successful, then try booting it normally. If it fails, we know we've got an issue.
Mar 23, 2012 | Acer Aspire X3400 PC Desktop
Power plug
Most LCD monitors use IEC sockets - these are 3pins sockets.
Power leads are available from computer shops and electrical stores.
Jun 06, 2010 | Microsoft Likom HD19A 19" LCD Monitor
Pl2010m orange standby light, black screen
Try booting the pc in safe mode (press f8 at startup). It may be possible that the pc is trying to send too high a resolution to the monitor...unlikely though. The symptom you describe usually indicates that the power board or the inverter board in the monitor are defective. If it does the same thing in safe mode, you have 2 options.
1. Replace the power board and inverter board (do the inverter board first.......it's the cheaper one (10-20 dollars).
2. Send the monitor back to the seller for a refund, or get a new monitor.
Sorry I couldn't give you more positive feedback. Hope this helps.
Joe
Oct 13, 2009 | Planar PL2010M 20" Flat Panel LCD Monitor
Monitor stuck in standby
Try tapping F8 when booting and then choose 'safe mode with networking'
if this works go to the lcd manufactures web site and look for a specific driver for your screen.
Aug 30, 2009 | Dell E551 15" CRT Monitor
19"chimei Lcd. Screen stays black.
probably power supply, dac-19m015, 2200uf bad capacitor.
Apr 26, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
Vusys hd19a monitor is always on standby
Cut and paste from another site:
I was called to repair similar incident last week. A Compaq box (don't remember the model) with a 'smart' usb keyboard. By this I mean that the keyboard had a row of what I'll call hot buttons. The client had pushed a button with a moon on it causing the monitor to go into sleep mode. I suspect that whatever key you pushed had the same effect.
After plugging a known good monitor into the faulty box I verified that the box was OK. This left me to think the monitor itself had a problem. Plugged the suspect monitor into a known good machine.. and it worked fine!!!
Set machine and monitor to original configuration and still had no video. Decided that the monitor was too smart for its own good and maybe there was something in the monitors menu. Pushed and held the 'menu' button on the monitor for a few seconds and menu comes forward. Green power led also comes on (surprising me) so I powered up the computer and lo and behold the problem is fixed!
Dec 11, 2008 | Microsoft Likom HD19A 19" LCD Monitor
HD19A / 19-Inch light flickers but no display
One of 2 possibilities come to mind.
1,  The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
Oct 12, 2007 | Microsoft Likom HD19A 19" LCD Monitor
When the PC starts the monitor does not come out of the power standby mode
Hi The problem is to do with a 680uf capacitor that tends to bulge and fails.this stops the monitor staying on when trigerd to do so,change this and happy day.
Jan 16, 2007 | LG Flatron L1715S 17" LCD Monitor
Monitor problem
I have had similar problems. It would appear that the power supply is at fault, not the monitor.
Dec 27, 2006 | Microsoft Likom HD19A 19" LCD Monitor
Microsoft Likom HD19A 19" LCD Monitor Logo
195 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
