How do i install 2 different printers
I have a compaq computer and a HP 4280 all in one printer with paralell port connection and i also want to install a Samsung 2510 laser printer that has a usb connection.so how do i install and make this work?
thanks
    President:
  • 1,901 Answers
It shouldn't be a problem at all. Follow the setup CD that came with your printers. You may have to enable the parallel port through the BIOS Setup if it isn't already. Remember when you setup the 4280 that it will be connected to the LPT1 port.
Posted on Oct 20, 2008
    Problem Solver:
  • 13 Answers
Install the 4280 driver. Make this your Parallel connected printer. Then install the Samsung by clicking add printer, then when prompted for a port, click USB (USB001). After you load the drivers, just simply select which printer you want to send the document to. Once you successfully load the drivers, you will be prompted to print a test page. If you get a test page from both printers after loading the driver(s), you have installed them correctly.
Paralell print cable to usb adapter
go to your control panel & delete the printer, shut down & restart turn the printer on after restart see if the computer sees the printer if not try reinstalling if this doesn't work possibly the adaptor
Dec 22, 2011 | HEWLETT-PACKARD LaserJet 6P / 6MP (H3966A)...
My HP Printer no longer works on my laptop. What
you did not provided any useful information, what operating system you use, what printer, what connection (usb, paralel, network) and what laptop.
general advice only can be provided then.
if windows of any flavour, disconnect the printer, uninstall all software pertaining to this printer. use ccleaner and clean your harddrive including registry.
check printer on another computer if it works. if printer works correctly, problem is with your laptop, not with printer.
follow this procedure, install software, connect printer, switch printer on, windows will automaticaly install drivers and printer software
if this do not work, you need to check if port used for printer work with other hardware, ie, usb stick, check cable between printer and relevant port.
Jul 20, 2010 | HP Computers & Internet
I have an HP Photosmart 4280 All in oNe printer scanner. The canner stopped working in the middle of a project - sais that the USB was not connected. I looked at your site and downloaded new drivers. ...
uninstall the printer software from ur computer restart and the reinstall the same, disconnect the printer while doing all that and the connect the printer to a different usb port bro
Jan 11, 2010 | HP ScanJet 2200C Flatbed Scanner
My HP LaserJet 2420 has disappeared from my "printers" control panel. The printer is connected via USB. I have swapped cables and have tried to install it on another computer with NO result. There are NO...
There might be a problem with your computer as well. Try printing with paralell cable to make sure the interface works at all. If the patalell-port works fine, try updating the printers firmware. Still problems ? Try with a different computer. If if works fine with another computer, then you know theres something wrong with your first computer. Good luck.
Aug 10, 2009 | HP Hewlett Packard LaserJet 2420 Printer
Hp laserjet 1100 - won't print under Win'98SE i've got this printer and can't use it on a computer under win98SE. under XP works fine! all the ports seems to be bussy, and request to increes the timeout...
Try changing the LPT port mode in the BIOS- there should be like SPP, EPP, ECP. As I recall there are different drivers for USB and Parallel and I don't think Serial is supported. If you installed HP drivers, Uninstall and use the Windows drivers.
Dec 07, 2008 | Office Equipment & Supplies
Canon bjc 50 printer
You are correct on your deduction.
It is the USB to Parrallel adpter. They are not reliable in the XP/Vista enviroment. I have run into this several times.
Oct 07, 2008 | Canon Office Equipment & Supplies
Can't find my printer!
how did u connect the printer, (USB, Paralell, Network), if it is usb and is connected to a pc it must appear, if doesn't u may have a motherboard problem, if it is paralell or network, u must instal the printer as a paralel printer and if it is a network after u install it u must change the port to a IP port.
good luck
Jun 01, 2008 | OKI C5100n Laser Printer
Connecting my HP ScanJet 5200C scanner to my HP Pavilion Home pc
Rookssailor,
I don't think you can (successfully) run this scanner off the paralell port. I'm drawing on memory here but I think this scanner has serial and usb ports. If you are running Windows XP, use the USB hookup. If you are running Windows 95, 98, Milliniaum then you might want to use the serial port. At any rate the scanner software should be installed before you plugin the scanner.
If I'm completely "full of it" and you really want to use a Paralell connection then you might want to use a paralell to USB adaptor (Belkin, perhaps others make one of these).
haMAR
Apr 01, 2008 | Office Equipment & Supplies
70 people viewed this question
k24674
jasbo
jasbo
