Westell 6100 Can I hook up 2 computers and access the internet at the same time-one USB and the other eathernet This HW was provided by Verizon DSL servcie
  • Anonymous Apr 24, 2009
    USB SETUP WITHOUT CD???!
  • 6,487 Answers
You cannot use the UBS and ethernet conenction of your modem at the same time, so it only means that you can only use either the UBS or the ethernet connection of your modem and since you want to use to computer and get online at the same time you need to have a router to share the internet connections on 2 computers at the same time, you can get this router BEFSR41 or WRT54G...
Posted on Oct 20, 2008
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
Blinking light on Westell 6100 DSL modem
I have a westell 6100 modem also- The light your are talking about always blinks- it blinks as long as the internet is working (it is sending and transmitting data)
May 28, 2009 | Westell Wirespeed LiteLine 6100...
Resuming verizon dsl usb internet connection
If you reformatted your Windows on your pc, there's no need to change the settings of your network connections. The Westell 6100 can either be connected to your pc using the Ethernet port or the USB port if you're using the combo cable or Y-cable. It's more stable to use the Ethernet port for your Lan connection. For the USB, to reinstall the USB connection properly, you'll need the Verizon Installation CD. Make sure the USB is not connected to your PC first before you install it. You just need to follow the CD because it will tell you when to hook up the USB cable to the pc. If you still have the CD, after it runs, you have to select existing customer and then select connect new modem. After that you just to have follow the steps to install the USB connection properly and then your modem will work fine afterwards. If the problem still persists, you can try replacing the cable. If all else fails, it could be a modem problem already. You also need to check your Network Interface Card of NIC as we call it, it's built in your pc. it's the device that allows your pc to communicate with the modem. Normally after reinstalling windows, the NIC is forgotten, make sure you also install the drivers and utilities Cd for your windows.
May 18, 2009 | Westell Wirespeed ProLine 6100 Router...
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
Apr 10, 2009 | Westell Wirespeed LiteLine 6110 Modem
DSL loses signal during VOIP call.
hi,
i worked for verizon for two years and I encounter this problem many times,to tell you honestly,its not with you internet connection since if you'll notice,while you are connected to the internet and you make a call or call someone,its interrupted... Obviously,its the phone itslelf,the signal comng from the phone is different from the signal of the internet...thats the reason why you need a modem to convert the signal coming from the phone line to make it work for internet,,,what I suggest is you change the DSL plan from the Dry Loop to the regular dsl with the phone...
thanks and God Bless
Mar 20, 2009 | Westell Wirespeed LiteLine 6100...
Blinking light means that firmware on your DSL modem just got updated. The modem is pinging the Networ/Computer connected to it. If you open your Modem Page 192.168.1.1 you will see the difference, unless you never have done it before.
Jan 25, 2009 | Westell Wirespeed LiteLine 6100...
WESTELL WIRESPEED DSL MODEM B99-210014-03
Probably not - contact your DSL internet service and ask what modem they suggest.
Sep 26, 2008 | Westell Wirespeed LiteLine 6100...
DSL Modem
That means that the phone is interfeering with the broadband. Often you fix this kind of problems by replacing the broadband filter. If it does not work after replacement it means there is a problem either with phone line or with broaband provider.
In this case contact first ISP (broaband provider), then your phone company to locate the problem.
Most likely it is the filter.
Regards
May 05, 2008 | Westell Wirespeed LiteLine 6100...
No Internet light, but an Ethernet light that blinks?
for westell 6100 modem usb driver installation follow the steps for windows xp
-close all programs
-unplug usb cable from the pc
-insert installation cd from verizon
-plug usb cable back to pc
-wizard will pop up found new hardware
-click next then follow instructions
-select usb connection on the installation
Dec 14, 2007 | Westell Wirespeed LiteLine 6100...
Computers & Internet Logo
404 people viewed this question
David Payne
David Payne
