Sony Aquos damaged by kids. It looked like it was cracked on the inside, and now it won't work at all. Is it worth trying to fix?
  • csc0tt Oct 20, 2008
    It's the screen on the inside, not the plastic on the outside. I'm not even sure of the exact size, as the tv was given to us by my father-in-law. I'd say it's medium-sized.
  • 22 Answers
Depending on the size it might be.
is the screen damaged or just the plastic?
Posted on Oct 20, 2008
How to fix a crack inside a LG LCD TV
The short answer is a cracked LCD is not worth repairing.
Here is a link to some more info, cover cost and whats involved.Broken Screen's Repair and Info Cracked, Broken, Smashed Bad LCD, Plasma and LED Panels
Jun 10, 2012 | LG 42LC2D 42 in. LCD HDTV
Can you fix this cracked screen problem on Vizio VW42LFHDTV10A? and no sound?
We used to say have a short service on the patio and buy a new set---damaged panel display unit is more than set cost (if it is even available)
Let it go---when damaged it can instantly damage other boards/parts in the set.
Run a car with no oil and see what happens........
Mar 20, 2012 | Vizio VW42LF 42 in. LCD HDTV
How much will it take to fix a cracked membrane with vertical lines on it
Not worth fixing,if the LCD screen panel is damage or broken.Because LCD screen it limited produce it will cost the same as a new tv.Might even cost more after the LCD screen panel part and labors.The LCD screen panel is 90% of the tv,broken or damage LCD screen panel not worth as a whole tv anymore.The tv now only worth as salvage electronics boards parts.
Apr 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cracked screen on 32" SONY Bravia HD 1080p, how much would it cost to fix?
It will be more what the TV is worth and you can actually get one. You can look here to see what some of them go for: www.shopjimmy.com
Jan 06, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Sharp Aquos LC-42D62U 42 in. HDTV LCD which was bumped into pretty hard and the inside screen on the tv cracked. The crack is only visible when the tv is on can this be fixed or is it garbage
Unfortunatly it is garbage basically.. You can have them repaired using a TV Repair guy but often it costs as much as a brand new LCD. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Jan 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cracked LC37D62U LCD TV
It is broken,The outside is a Polorised film.Like window tint,It is repairable,New LCD screen.But may be cheeper to buy a new TV. GET A EXT.WARENTY!!! will not cover accidents but the new tv's do break alot,and are expensive to repair.
Buy a name brand, NOT RCA "junk" Just a name
no longer a company. Samsung,Panasonic,Sony. If you want to support the USA buy another Sharp. Still a great TV. And made in America. NOTE they make after market screen protectors. GOT KIDS? GET ONE. :) Or even a piece of plexie glass if cash is tight. Hope this helps.
Oct 25, 2009 | Sharp LC-37D4U 37 in. LCD Television
Cracked screen on 46 inch lcd sharp aquos
hi you looking at 1400 for just the screen if you had your tv less than a year then you are covered for one year by sharp so what i would do is call sharp and see if your covered on cracked screens
Jan 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Cracked LCD Screen on Sharp Aquos LC37D43U 37-Inch 720p LCD HDTV
Most LCD's just went down in price by around 2-400 dollars. I would suggest buying a new one. The cracked screen might mean that the liquid will ooze out and get worse and worse as it ages. However, it may only have a crack and not get any worse than it is now. If you can live with it and it doesn't get worse, you can view it that way for another 10 years and be fine.
The fact that the LCDs are cheaper now and you only have a 37 inch, you might consider getting a larger one that you have had your eye on for a long time. (Note: even though I am a firm believer in LCD's over Plasma, plasmas are a few hundered dollars cheaper and if you know your children are prone to breaking things... it might be the way to go.)
Replacing the screen is possible, but more costly than the new T.V.
Dec 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 15 LCD TV
Maybe. Unplug the unit and disassembly it. Look for damaged parts or cracked circuit boards. You may also find the buttons you push to turn it on and activate the menu ect. may be damaged. In most cases the board can be repaired but because that would be time consuming and the repair man charges 60 bucks an hour it is usully not cost effective. You might get lucky and find a wire that fell off in the fall. Good luck.
Apr 20, 2008 | Sharp 15" AQUOS LCD Flat-Panel LC15B4US...
Screen cracked from the inside
It's the LCD panel damage. You need to replace the whole LCD panel to get this problem fixed.
Jan 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
