Question about Sony Playstation 3 (PS3) Console
Help Just got used ps3 when I turn it on it has good picture but no sound I have tried on 2 TV?s but it does the same thing no sound when I try to quit the game it quits and takes me to the auxiliary channel on the tv
My problem is that the sound will come out of the playstation but there is no picture, we thought it was the cord but tried 2 different cords.
Posted on Oct 20, 2008
  • 22 Answers
Check the audio output settings it might be set on digital out
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
BOSE Lifestyle System w/VS-2 video enhancer - No Picture
Hi, First thing unplug both ends of the cable and replug them in.
After that we will work from there keep me updated,
Jun 16, 2008 | Bose LIFESTYLE VS1 Lifestyle174; VS-1...
I have a 47 lg lcd tv bought in 09. When i use hdmi for xbox 360 i get picture and sound but with ps3 no pic no sound. I just bought a sony bluray and get pic but no sound. I bought a lg bluray and get no...
To clarify, your TV is working correctly, since you get sound and video from all devices - Only your PS3 has no sound or video?
If your PS3 was previously used with regular AV cables (Red/White/Yellow) then you most likely need to do a PS3 video reset t output video over HDMI.
With the PS3 OFF, press and continue holding the power button until it turns on, beeps twice, and then turns back off. Do not release the power button during this process.
You may have to try the video reset a few times if it doesn't work right away.
After video reset, you should get sound and video over HDMI.
Nov 08, 2017 | LG 47LF11 LCD TV
Have good picture, but no sound from Wii
Make sure no other game console is hooked up to the spliter then turn everything off... turn the TV on first, then the game system, if the system still doesn't produce sound then get a NEW dedicated cable Hope that helps
Aug 21, 2009 | Nintendo Wii Console
No picture coming up on tv from ps3 ps3 turns on but no picture comes up on tv.. tried it on 2 tvs but same happens
ARe you getting sound?I suspect it might have flipped to hd or back to standard def, depending which setting you originally had it on Try holding down the power button when you turn it on, untiil you hear 2 beeps, this should reset the visual settings on the ps3
Jul 30, 2009 | Sony Playstation 3 (PS3) Console
Sound but no picture on PS3 using AV3/4
if it's happening with your ps2 and your ps3 on teh same tv, try it on a different tv. if you're getting sound but no picture, tehn it's something with your cables or your tv. restting the display setting should get your picture back up. make sure the system is in standby and then hold down teh power button. it will turn green and beep, then flash green and beep again. it should brng up a picture. if not, check your component cables, especailly if it works with the original cables.
Apr 06, 2009 | Sony PlayStation 3 40GB System
Working but no picture or sound
power of the ps3,remove the hdd.turn on the ps3 without the hdd.picture should come in about 1 to 2 minutes.return back the hdd,hope i helped you
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
No picture no sound
PS3 is The amazing device by sony but it has some common problems like sound problem, video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Oct 14, 2008 | Sony Playstation 3 (PS3) Console
PS3 no picture and no sound
Try turning the system off completely with the main power switch on the back of the console. If that doesnt work call Sony technical support for further help.
Aug 04, 2008 | Sony Playstation 3 (PS3) Console
Full HD picture NO SOUND from ps3 to lg42hd using HDMI
Maybe your TV is not made for HD from the Sony Console. Try calling Sony Customer support, then your TV's brand Customer support. That will tell you if your TV Model allows the HD from the PS3. Remember though, PS3 Uses Blu-Ray. So you need Blu-Ray for your TV. Hope this helped.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
