Question about Samsung SyncMaster 1200 NF (Ivory) 22" CRT Monitor
Menu not in centre of screen and unable to see volume bar
When I go into menu to change settings, half of the menu control is at the bottom of the screen and the other half cannot be seen. I am also unable to see the volume bar
    New Friend:
  • 62 Answers
1. Solder the vertical IC. & IC supply capacitor.
2. change the vertical IC
Posted on Nov 22, 2008
How do I turn volume up
To change your computer's volume, click the Volume control in the menu bar, then drag the slider to adjust the volume. If the Volume control isn't in the menu bar, choose Apple menu > System Preferences, then click Sound. Click Output, then select the "Showvolume in menu bar" checkbox.
Mar 14, 2016 | Alcatel One Touch FIRST 20 Cordless Phone
How can I set time and volume?
These 2 things can be done using the "Menu". (You can also adjust the Volume from the Driving Screen - tap bottom left area and slide the volume bar to adjust the volume).
From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen),
Look for, and tap on "Change preferences".
1. To set Time:
On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time.
2. To set Volume:
On the next screen, look for and tap "Volume preferences". You can then tap on the bar (position) and test/hear the level of the sound. And/or you can select "Link Volume to car Speed" ... and tap Done.
Feb 11, 2016 | Tomtom One GPS
Pioneer 4000 shuts off when touching anything
Reload software from Pioneers support web sight.
Jul 23, 2012 | Pioneer AVH-P4000DVD Monitor
How do you control volume on tom tom 130?
With the unit turned on and displaying the map, tap the bottom left side of the screen.
A sliding bar will appear at the bottom of the screen. You can now adjust the volume to your desired level.
The volume menu is also available by tapping and entering 'Preferences menu'. You can also set the volume from here if you wish.
Thanks for using FixYa.
Jan 01, 2010 | Tomtom ONE 130 GPS Receiver
RCA HDTV MENU AND VOLUME CONTROL POPS ON AND OFF SCREEN.
My TV was doing the same thing. Someone told me to disconnect the front menu buttons and this worked for me. The board goes haywire. You have to take off the front black panel on the bottom first then the grey front panel where the controls are. Once you do this you will see where there is a plug from tv to the panel where the control buttons are. Just disconnect. You will only be able to use your remote for TV. Its a cheap and easy fix. Just lots of screws to get the panels off and on. Good luck!
Apr 09, 2009 | RCA HD52W58 52" TV
Unable to access menu with remote control
you cannot enter into menu on most universal remote only on off switch,channel change and volume up and down thats the most you can get out of a universal remote.you will need the originald remote.
Mar 04, 2009 | Emerson Televison & Video
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Samsung SyncMaster 1200 NF (Ivory) 22" CRT Monitor Logo
136 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
