Technics EH760, can I remove the tapedeck??
I have no use for the double tape deck for my technics system. If I cut and insulate the flat "computer hard drive type" connector will this harm the rest of the system??
  • 10594 Answers
SOURCE: Technics RS-CH770 double tape decks
Please check Capstan Motor working / rotating. If no, check its supply volts. If yes, then check Capstan Belt and FR Belt, should not be any cracks on it. If found cracks, please replace them.
Posted on Aug 13, 2008
  • 515 Answers
SOURCE: Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
Posted on Dec 18, 2008
  • 62 Answers
Make sure the output in your tv menu is set to external speakers. Any digital optical cable, or RCA jacks hooked up properly from the TV's out put to the receivers input should work just fine. Take your time, retrace your steps, and make sure each cable is in the correct input/output. And make sure the receiver and TV are on the proper settings. Good Luck, and thanks for using FixYa!
Posted on Jan 13, 2009
  • 4234 Answers
SOURCE: where can i get service manual for my Technics sc eh760/790
I believe that these units use amp-pacs which look like large black ICs with multiple pins. If you can post the model number of the main unit, I should be able to get you the part number and cost. The model you list is the system model and I don't have a cross reference for those.
Posted on Feb 18, 2009
  • 99 Answers
SOURCE: I need to know how to record 1 tape onto another
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Posted on Jun 29, 2010
I have an old technics su-z22 amp and a denton tape deck with an it seems an incompatable record out socket from the amp and two rca sockets on the tapedeck how can i marry the two up
Having looked at the back of the model referred to I see two sets of RCA sockets for the connection of two tape decks. So I don't know what you mean by incompatible record out socket? There is a 5 pin din but you can use the two RCA sockets to connect the tapedeck. If you have a good quality RCA lead it should record and playback. You can in fact connect two tape recorders to this unit using the RCA sockets.
Apr 11, 2013 | Audio Players & Recorders
Can I use a microphone through a technics rs m216 tapedeck?
The tape deck was designed for stereo recording using two separate mikes, one for left input and one for right input
Jun 28, 2012 | Technics Audio Players & Recorders
Can I remove the cassette deck from my Technics SH-DV290 ?
Of course you can, remove deck from system get a pair of scissors cut the wire all the way through that is connected to the tape deck, tape up the cut and reconnect the wire to the dvd part and main equaliser. All done. Tried and tested :)
Feb 06, 2012 | Technics Audio Players & Recorders
Usually the fault is the failure of the BELT on the mechanism. You will need to remove the covers to have a look on the motor drive behind the mechanism of the tape drive. Thebelt can be changed if you are technically capable to remove and reset the mechanism.
May 06, 2011 | Technics RS-TR272 Single Cassette Deck
Cuts out
Check your speakers. your speaker may be defective
Dec 17, 2007 | Technics SUV500 2-Channel Amplifier
Technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
May 14, 2007 | Technics SCEH790 CD Shelf System
63 people viewed this question
