Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Pull Cord appears to be sprung
Weed Eater SL 1500
  • topgun1195 Dec 05, 2008
    Pull cord will not retract - I took this apart and the spring is not broken, but, is a jumbled mess. How does one get it back into the correct position?
KMusselmann
  • 247 Answers
SOURCE: starter rope on bv2000 weed eater blower needs to be replaced.
Hi, Try the following, But make dure you can wind the spring. If not the spring is broken.
Kurt
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Posted on Mar 23, 2009
  • 3600 Answers
SOURCE: WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Posted on Aug 13, 2009
bulldogchief
  • 388 Answers
SOURCE: Can't get weed eater started. Have an older weed
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Posted on Sep 17, 2009
Testimonial: "thanks...I will give it a try and keep you posted"
suzukiracing
  • 200 Answers
SOURCE: my weed eater starts but won't stay running. what
Try a new spark plug.Thanks for asking and I hope it helps
Posted on Jul 21, 2010
HansPP
  • 2510 Answers
SOURCE: I have a poulan/Weed-Eater blower
Try a now spark plug first. If it is still hard to start then it is probably because of low compression due to worn rings and these need to be replaced.
Posted on May 22, 2011
Pull cord on weed eater won't engage
If the pull cord does not turn the engine over, the starter pawls are probably not working properly.
Jul 13, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Pull on cord for weed eater y 28 yard machine hard to pull how do i repair it
Hmmmmm. The question is why does it pull hard to begin with? Did the pull cord get wrapped around the pulley in an awkward manner or is the machine seized up? If it's not to difficult, pull the muffler off the machine and look at the piston. If it looks scored (lines up and down the piston through the rings) It's shot and probably not worth fixing. But, If everything looks good, then I'd pull the starter assembly off and see if there's something going on there that's doesn't look right.
Sep 23, 2012 | Garden
Weed eater made a noise then just quit working, pull cord wont engage
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~ i need to know this before i can give you a answer,,
Jan 23, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
118 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
