Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Vacuum brush Everytime I try to vacuum the vacuum makes a very loud noise and starts to shake. I'm thinking it is the vacuum brush because it feels like that's where the shaking is coming from. Could it be the brush?
  • 566 Answers
Your suspision may be correct especially if vac is well used/older however may i suggest you turn vac over and investigate by removing the brush cover plate? then you may see what problem is?this could be debri trapped in roller/brush housing? or the bearings/bushes at each end of bruch may be worne or even come loose from their seats whatever is causing the vibes i feel sure you will find on removal of the cover hope this helps/inspires you to diy good luck
Posted on Oct 20, 2008
Why s it starting to make loud noise?
you might have picked up a hard object like a dime or screw that won't go into the bag. Pill out the brush and shake it downward and look for something falling out.
Feb 14, 2016 | Hoover Platinum LiNX Cordless Stick Vacuum
Shark nv350 making loud noise when switched for carpet
HI, it's Jim from Crucial Vacuum!
If your Shark NV350 vacuum is making loud noises when switched to carpet then there are a few parts of your vacuum you can check to resolve the problem.
First thing let's check your vacuums canister. The idea is to prevent clogs and anything that will obstruct your vacuum from operating properly, and running smoothly without noise. You'll want to empty your canister after every use.
Secondly, let's check out your brush roll. Is there hair wrapped around the roll itself, or any noticeable debris that would prevent the brush roll from turning? If so remove it and manually rotate the brush roll to help unearth any hidden clogs behind the roll.
While you're examining your vacuums brush roll take a look at the belt as well. If the belt isn't wrapped around the brush roll properly this could be causing the noise. The belt should have a good bit of tension on it in order for the brush roll to turn properly. Your vacuums belt should be replaced roughly every 3 months. So be sure it's on properly and has a good bit of tension.
You can purchase replacement parts for your Shark NV350 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=NV350&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim
Crucial Vacuum Customer Care
Mar 19, 2015 | Shark Navigator Lift-Away NV350
Why is my hoover spin brush making a loud noise when i turn it on
Check for clogs starting with the air passageway at the bottom.
A piece of TV cable or similar works well as you have to snake
it in. Check all hoses, Are the filters clean? If you can, remove
the brush bar and belt then turn vacuum on. If the vacuum is
no longer making a loud noise the side bearings on the brush
bar are the problem...replace the bar or spray a bit of WD40-
if you do that wipe well before you vacuum. Finally....if the
vacuum was still loud with the brush bar off...you have a motor
problem and that could be expensive.
Regards.
Dennis
Aug 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Squeeling noise dyson 33
Is it when you go from carpet to floor or floor to carpet? It will make a loud noise detecting a possible suction issue. I've also had loud noises and turned over the vacuum and where the brush is, traps hair, thread, rubber bands, etc. Just take a scissor and cut it all out. Don't cut the bristles. Roll the brush as you cut and pull all the stuff wrapped around the brush. Once it is free, try it again.
Jul 27, 2014 | Dyson DC-33 MultiFloor Upright Vacuum...
Vacuum shaking badly right up to handle and very loud noise
Could be a broker motor retainer. There should be two motor retainers in this model, when one is borken, it causes the unit to
shake and vibrate.
May 13, 2010 | Hoover U5507900 Elite Rewind Bagless...
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum problem
Check the brush roll, do the ends turn freely, if not, replace it. Could have a clog in the hose or the dirt inlet by the brush roll, the other could be a bad motor.
Mar 19, 2008 | Vacuums
Hi.
You either need A new clutch or clutch belts need replacing.
Its a lot to describe so try this it has manuals on how to do the job.
http://dysonmanuals.inc.io/
Oct 14, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum Roller making a loud noise
Your roller brush is starting to fail. If you unscrew the ends, you will find a lot of hair wound around the stem. You probably have a warped plastic end the holds the bearing. This is my problem now.... I am looking for a new roller brush as I write this. I found one for $30. Good Luck.
May 11, 2007 | Hoover U5018-900 Bagged Upright Vacuum
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
118 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
