Hey how u doing, how did u fix ur laptop problem (password problem) i have the same here... i cant remember my password :S A215-S7437
  • encio May 11, 2010
    I can;t remember my password
How can i reset bios password on my toshiba satellite A215-S4807
sir.Please condact service Engg. Or
Open your laptop and removing CEMOS battery then shotting CEMOS soket inside two connections.ok thanks
Sep 30, 2011 | Toshiba Satellite A215-S7437 Notebook
My toshiba laptop is asking for a password it will not boot without it as soon as you turn it on it wants a password
BIOS is set to password on....
did anyone make changes to ur laptop....
if so then only he can unlock it....as BIOS passwords cannot be unlocked....they are embeded in the BIOS microchip...
only a BIOS update can undo it...and that's very RISKY...
Oct 31, 2010 | Toshiba Satellite A215-S7437 Notebook
I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
Nov 04, 2009 | Toshiba Satellite A215-S7437 Notebook
I have a Toshiba Satellite A215-S7437 and suddenly appear a password at the begin startup. What Can I Do?
that is a bios password it is a common problem when bios software isnever updated. it is covered under an exception code i believe. email me your model part number and i will tell you the rest of the process monday. or if you want to do it yourself the pin is located under the ram, it looks like two interlocking E's take a flathead and press in between the two
Oct 31, 2009 | Toshiba Satellite A215-S4747 Notebook
I have a password in bios i did not put there. how
carefully remove CMOS battery and leave it out for 30 minutes will reset defaults and will remove all passwords associated with power up pass and BIOS.
Oct 05, 2009 | Computers & Internet
BIOS password won't turn off
You wanted one you got one. Only way to clear is to reset the BIOS by removing power,laptop battery and BIOS battery on MoBo. That involves taking laptop apart.
Weren't you being clever!
Sep 20, 2009 | Toshiba Satellite A215-S7437 Notebook
Toshiba a215-s7437 bios password what is it?
from release it doesn't have a bios password, the shop who slod the laptop to you must have put the password in, or maybe someone you know put it in. the only way you are going to get around this is to ether give the password from who put it in or take it to a IT shop and have them remove the bios battary overnight and then put it in again. that will remove all password settings and change all bios settings back to default settings
Aug 14, 2009 | Toshiba Satellite A215-S4747 Notebook
Toshiba Satellite A215-S7437 Laptop Password Problem?
You should first check if the pasword is set on the hard drive. If so you can simply change the hard drive and it will then boot and ask for the operating system disk. If not, you should try by removing the cmos battery and waiting at least 10 minutes. (this works on older laptops) however, the laptop's power suply cable and battery should be removed prior to performing this procedure.
Jan 10, 2009 | Toshiba Satellite A215-S7437 Notebook
Computers & Internet Logo
David Payne
David Payne
