Question about Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 350 Calibration Issue
My nephew got ahold of my nuvi 350, and somehow got to the screen where you calibrate the touch screen. As he was trying to push the dots on the screen, somehow it calibrated in such a way thats it's nearly impossible to use now. I try to get back to the page but it is so hard to find the right area to touch on the screen to make it work.
Is there a way to reset this unit back to all its factory settings, this way the calibration resets to normal again?
thanks
  • MishkaStarik Nov 17, 2008
    Hi Sharcnet,
    I got exactly the same problem tonigt. I tried to follow your steps and after "booting" it comes to the "loader" mode. I coudn't get the calibration screen.
    Any other ideas?
    Thanks,
    Misha-
  • bueller555 Jan 25, 2009
    Same problem here. I followed the steps and didn't let up on the power button, but after the Pre-Boot and Booting messages appear, the word Loader appears then Loading Software... then the unit cycles back to Pre-Boot etc. I've tried letting up at different times, but no luck. Any other ideas of how to get to the calibration screen? Thanks.
  • Garmin Master
  • 2,130 Answers
Turn the unit off. Press and hold down the power button and keep holding it. You will see the screen light up and it will say "pre-boot mode". Keep holding down the power key. It will then say "booting". Keep holding the power button down. You'll then come to the calibation screen. Select the dots and you'll be back in business.
- Jim
Posted on Nov 13, 2008
  • SHARCNET-USA
    SHARCNET-USA Nov 17, 2008
    If you let up on the power button at any time, that's why it didn't work. Hold the button down and don't let up off of it until you see the dots screen.
    - Jim
  • SHARCNET-USA
    SHARCNET-USA Nov 18, 2008
    There is a possibility that the touch screen cable inside is loose or not making good contact inside. This can happen if you have dropped your nuvi. I've seen it happen many times.
    - Jim
Answer I found on the Garmin website:
Q. The touch screen is not responding correctly when I touch it. How can I re-align the screen? A. In order to calibrate the screen, please to go to the Main Menu page. From there, touch Settings > Display. Tap on the Recalibrate button and follow the on-screen instructions.
Posted on Aug 19, 2012
Hi Jim, The strange and good thing happened the next morning: even I could not get it working last night - I turn it on the next morning ...and...it worked ! Still have no idea what was the problem. Thanks for you help! Misha-
Posted on Nov 18, 2008
Screen touch has no response
Welcome to Fixya.
This is a known issue for Garmin nuvi 550 and 650.
Re-calibrate your touchscreen.
Press and hold the power button 2-3 minutes, the unit will enter the calibration process. Calibrate as instructed.
Thank you for using Fixya, have a great day.
Jas247
Jul 22, 2011 | Garmin nuvi 650 GPS Receiver
How to calibrae my gps nuvi garmin 255????????????????
For the Garmin 2x5 series GPS
Calibrating the Screen:
1. Turn off the nüvi.
2. Hold the upper-left comer of the screen white turning on the nüvi
3. Release the power key when the Garmin screen appears.
4. Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
Here are links to the manual for both the 255 and the 255W (wide).
I hope helped & good luck! Please rate my reply. Thank you.
Jun 30, 2011 | Garmin nuvi 255W GPS Receiver
I have a Garmin Nuvi 1450 that I bough in December 2010. This morning, when i try to type in an address, the touch screen is behaving erratic. For example, when N is pressed, it types M. Erase is not...
nuvis do not have a calibration screens or settings, to fix your issue try updating the units firmware with Garmins WebUpdater software this could fix your issue, it can be obtained from this link http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Feb 13, 2011 | Garmin nuvi 1450 GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Touch screen on my garmin nuvi 205 stopped responding
If the touch screen is not working properly, calibrate the touch screen.
Turn Nuvi off and then back on.
Slide power key to the right (lock). Hold your finger on the screen for about 30 seconds until the calibration screen appears.
Follow the directions on screen instructions
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 1350:touch screen calibration
Hold your finger on the top left corner of the screen while turning it on. Release the power button when you see the Garmin logo pop up but keep your finger on the top left corner until the white calibration screen shows.
Apr 09, 2010 | Garmin nuvi 1350 Car GPS Receiver
My touchscreen lost it's calibration and I can't recalibrate it
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Jan 20, 2010 | Garmin Nuvi 660 GPS Receiver
My screen does not respond to my touch
You need to Calibrate the touch screen.1Turn off the Nuvi. 2 Turn on the Nuvi and hold the Power key to the left for about 30 seconds untill the calibration screen appears (white screen with "Press dot")
Nov 08, 2009 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 670 touch screen is not calibrated
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
SHARCNET- USA
Dec 09, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
1,275 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
