Question about Sony VAIO PCV-RX462DS PC Desktop
Cd drive problem
Eject button works on cd drive but the cd rom doesnt work. it also doesnt show up in the my computer area or the system manager. drivers are installed correctly.
  • 744 Answers
SOURCE: cd rom doesnt work at all
hi if ur system is provided with two drives then u can use the second drive.. if not then u have to go for a change of new rom..since u said that ur light wont even flash it means that ir drive doesnt detect that particular rom and it has got damaged....
thank u rate me
Posted on Feb 09, 2009
  • 700 Answers
SOURCE: CDrom drive is no longer working. When I insert
You can try to transfer your cdrom content to a flash drive if your laptop support usb port.
Posted on Apr 17, 2009
  • 19 Answers
SOURCE: where can i get driver
use things like driving detective or something. it automatically gives you updates for your hardwares that needs updates
Posted on May 20, 2009
  • 102 Answers
SOURCE: Windows cannot start this hardware device because
try to uninstall the cd rom.... then restart your computer
Posted on Jun 29, 2009
  • 70 Answers
replace drive 35-50 bucks i reccomend a lite on
Posted on Aug 22, 2009
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
DVD ROM cant read any cd or DVD
Try uninstalling the drivers and rebooting.
Jul 02, 2008 | Computers & Internet
Can't eject CD from CD rom
Disassembling may be your only option, if the CD is Broken or jammed. Try rebooting and pushing the DVD rom button at boot. I had a DVD explode, I had to remove the drive and disassembling the DVD rom to remove all the pieces.
Apr 07, 2013 | Acer Aspire Z5700 All-in-One Desktop Pc
Cd stuck in emachine and there's no pin hole
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Jun 15, 2012 | E-Machines emachines (emachinees) CD-ROM...
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
May 21, 2010 | Apple iMac G5 Desktop
How am i going to eject the disc manually?
Hello there:
This sounds like to me that your cd rom device is going out on you when the disk gets stuck and refuses to come out what you can do is to get a paper clip and sraightren it out now look on the cd rom door and you will see a verry small hole if you press in on the door button and insert the paper clip in the hole when you see the light for the cd rom door turn on press in on the paper clip failrl hard and it will release the locking mechanism and the door will open for you.
you can try to clean the entire tray and the slides tht the tray runs on get some canned air and spray the area really well on both sides and see if this helps
If not that you may want to consider havaing the cd rom drive replaced ok
Hope this is very help ful for you
Best regards Michael
Jan 16, 2010 | Dell Studio 15 Laptop
Hi, I have two cd drives that originally came with the Dell dimensions 3000 PC home edition I own, I've had them for a while, but recently my cd drive has ceased to work, the computer doesnt acknowledge...
The best bet and I have had several customers bring systems in with this problem is you have to edit the registry file and get rid of the upper and lower registry values once you do this save and reboot the machine it is just like a new drive was installed worked on all of theres one however came back to me twice and it turned out it was a conflict with other installed hardware. Hope this helps If you simply go to and type clear upper lower registry values and the name and model of you drive as above it usually gives you a step by step and happy computing. Check us out on the web @ or contact me personally @
Jan 14, 2010 | Dell Dimension 3000 PC Desktop
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
Oct 10, 2009 | Apple iMac G4 Desktop
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Jun 18, 2008 | HP (176135-630) (176135630) Internal 48x...
Sony VAIO PCV-RX462DS PC Desktop Logo
59 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
