Question about D-Link MediaLounge 802.11g Wireless High-Definition Media Player
Ethernet Connection The ethernet connection no longer works, the wireless g connection does but is not dependable, is there are way to repair the ehternet (card) inside the machine? Is it a replaceable part?
  • wkwells Oct 20, 2008
    This is a Multimedia machine D-Link Media Lounge not a computer. Is the ethernet connection repairable?
  • D-Link Master
  • 6,487 Answers
If the ethernet card on your computer is built in meaning it came with the mother or its not an epansion card conencted to a PCI slot on your computer and its already bad, the best thing to do here is to get a new Ethernet card that will be connected to a PCI slot of your computer you can check this model number from Linksys LNE100TX or NC1oo ethernet card are not expensive so you can just go and get a new one...
Don't forget to rate the solution FIXYA thank you................
Posted on Oct 20, 2008
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
My router was hit by lighting. I replaced the router. The Xbox works fine, but I can longer play online. I replaced ther cable also. I think lighting may have damage the ethernet connection on the xbox
Lighting may have damaged the ethernet connection on the xbox. Take can connect your computer to the same lan port connection that you are connecting the xbox to and see if you can get on line. If so you may be able to save the xbox if you go wireless and install the wireless adaptor.
Jun 17, 2010 | Microsoft Xbox 360 Elite Console
My computer has internet connection through the port on the back, but not through the router for wireless networking. All the connections from the modem to the router and further to the computer are...
So, just to confirm:
PC via ethernet has internet connection OK?
The router IP is
The PC ethernet IP is 192.168.1.n (n is not 1)
If you unplug the ethernet cable, you no longer have a connection.
If these are correct, did you previously have wireless internet working? If so, just reboot the router (unplug its power).
If not, you'll need to check the wireless settings in the router with those of your wireless network card, making sure you are using matching security settings (WPA-PSK, AES256, matching 'key').
To access the router, browse to (ensure your ethernet is plugged in). If you haven't changed from the default login details, you'll find them in the router manual.
May 16, 2010 | Linksys WRT120N Wireless Router
I'm trying to hookup a usb modem broadband to a router for a desktop and laptop
This wireless router does not have any USB connection on it. Types of connection available on this router are wireless and Ethernet. You can check on the modem if there is an Ethernet port on it.
If your modem has an Ethernet port, I recommend that you test the Ethernet connection using one of your computers. We want to make sure that the Ethernet connection on the modem is enabled. If not, you may need to contact your ISP or the modem manufacturer to make sure that the Ethernet will work before you install the router.
If your modem does not have have an Ethernet port on it. This is not the router that will do the work for you. And I personally does not seen any router yet with the USB port for the modem.
Feb 10, 2010 | Linksys Wireless-G Broadband Router
Set up wireless security, now no ethernet connection with router
first try to repair your connectivity under network settings.If this doesn't work unplug both the power supply and router for a minute, plug them both back in and restart your pc. Let me know if this works.
Dec 26, 2009 | Linksys Wireless-G WRT54G Router
I have comcast cable net and D-link WBR 1310
Hi, forget about the USB connection since you wanted to use a router for your wireless connection. Contact Comcast asnd make sure they assist you in making your computer connect to the Internet using the ethernet connection because you are going to use the ethernet connection for the modem-router connection. Once your computer is online with the ethernet connection, you can connect your Dlink router to the modem and configure it for Internet connection. There will be more steps before you can use the wireless connection. Just make sure you can get online with ethernet connection first.
Jul 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Ethernet cable un plugged
If your wireless router has a strong connection then is your Laptop trying to connect to the correct Connection. Sounds like your talking about Fixed ethernet connection?
How many connections have you created in the "my networks" area?
Let me know,
Mar 07, 2009 | Computers & Internet
I cant play online without the modem being by my ps3?
Yes, using a longer ethernet cord will work, but the PS3 has a bult-in WiFi card that can connect to any wireless router (you can buy a wireless router from a computer store like BestBuy).
If you are going to buy a wireless router, see if a wireless G-mimo or wireless N with signal boost is within your budget. Try looking through the network settings to see if you can connect through the wireless router.
Or just get a longer ethernet cord and run it directly to the PS3 from the router. Ethernet cords are the most reliable connection, granted you are on a good internet connection, they won't get interference from things like mobile phones, cordless phones, microwaves, TV's etc.
I have both the PS3 and Xbox 360 and the only thing I like better about the PS3 is the free online game play and Blue-Ray. Other than that, they're even. Good luck and have fun online! If you find me (wraith0127) say hi! Don't forget to rate. Thank you!
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
I've just bought a SMC7904WBRA-N Wireless router with a SMCWUSBS-N2 Wireless adaptor. It's probably obvious to you but... I want my pc to have a wirelss connection but can I install the adaptor first...
Best results would be to install everything from a HARD wire connection. Wireless, can drop bits of data depending on interference. I would definately use the ethernet to install everything and then try the wireless.
Mar 14, 2008 | Computers & Internet
Ps3 wireless
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
D-Link MediaLounge 802.11g Wireless High-Definition Media Player Logo
Top D-Link Televison & Video Experts
David Payne
David Payne
Are you a D-Link Televison and Video Expert? Answer questions, earn points and help others
