Question about Garmin GPSMAP 440 Chartplotter GPS with Ocean Shoreline Info
Sonar not working properly, intermittent
I have a Garmin 440 on my boat. It works fine as I'm going slowly through a no wake zone (5 knots) but when I accelerate past 2,000 rpm or 15 knots, the readout blinks at the last depth and it appears the thing is not tracking with the boat. Any suggestions?
  • Dean
    Dean May 11, 2010
    Are you referring to the GPS tracking of your location or the sonar readout of water depth features under your boat?
    Problem Solver:
  • 18 Answers
Generally, that indicates air bubbles in the water under the transducer. If you have a transom-mount transducer, make sure the bottom surface is level or angled slightly down. If you have a thru-hull, make sure your bottom is fairly clean in that area.
Posted on Jun 18, 2009
Garmin 551s sonar stopped working, no bottom definition or ability to see fish GPS charts and speed all work It shows 3 step image repeats top of the screen / water surface has the transducer packed
Check you transducer cable route and connections. Look for kinks, punctures, & tears in cable. Visually check the transducer for damage. #2 check the units operation on a friends boat with the same set or research a local marine repair shop to check ops. Best of luck on the problem.
Jan 11, 2016 | Garmin Boating
Sonar intermittent very good through hull transducer , sonar works sometimes then will not work rest of day ,
Check the mounting location, check the cord connections, make sure the ducer is actually clicking when it is not working, otherwise either the unit or the ducer is going bad
Jul 29, 2014 | Garmin Gpsmap 441s Dual Frequency Combo...
Sonar not Working
Transducer not parallel to bottom - kicked up. Manually set depth to see if the auto depth is the problem.
Aug 12, 2017 | Lowrance Elite-4x DSI Sonar with...
Sonar is working erratically. Loses bottom and flashes. Anything to do other than replace the transducer?
I have a very similar problem. Unfortunately my boating season is over until next May. I found I was at software rev 2.30 and should be at 3.40 Some of the software updates were to resolve sounder problems.
Jul 04, 2011 | Garmin Gpsmap 498, External Antenna With...
Shows incorrect depth suddenly and Erratic displays
MY XD510c works fine then flashes 2.5 and fills the screen with black red blue white vertical lines...then after an amount of variable amount of time goes back to working for awhile
Jun 23, 2010 | Lowrance X510c 5" Screen Color 200 Khz...
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
I have a garmin gpsmap 440s that will only read sonar depths a no wake speed. When I increase speed much past this the depth number blinks but does not track or change until I slow back down to idle again....
Sounds like the transducer is installed at the wrong angle or in such a way that it is getting a lot of air from something on the hull. If it is a transom mount, check that it is angled correctly and not too close to the motor or aft of some kind of thru-hull fitting that will cause turbulence.
Aug 18, 2009 | Garmin GPSMAP 440 Chartplotter GPS with...
I have a recording software called Sonar 6 and every time i try to start it, i get an error message saying "sonar has stopped working". I have had the software for a few months and it's only just...
HAI,SONAR 6 SOAFTWARE WORKING PROPERLY IN THE MIDDLE IT'S NOT WORK OR FIRST YOU HAVE INSTALL THE SOAFWARE THAT TIME WILL NOT WORK.ANY WAY UNINSTAL SONAR AND REINSTAL IT'S WORK FINE.
UNINSTAL :
START>CONTROL PANNEL>ADD REMOVE PROGRAMS>SONAR>REMOVE.
RE-INSTAL :
DOUBLE CLICK FOR EXE SETUP PROGRAM FOR SONAR>SELECT TARGET AREA(DEFAULT C:\)>FINISH.
RESTART SYSTEM AND USE SONAR.
Jul 05, 2008 | Computers & Internet
Garmin GPSMAP 440 Chartplotter GPS with Ocean Shoreline Info Logo
256 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
