Question about HP Computers & Internet
All cd's are not working in the hard drive quote! "a copatable decoder is not installed on my computer". Previously was working ok!
  • 849 Answers
Download new version of media player from microsft, or install some other media player like media player classic, power dvd, jet audio etc.
Posted on Oct 20, 2008
Tip
How to backup and monitor a desktop computer
<p>The computer systems are based on the memory and storing information. However, as the crash of a computer system, causing loss of data, all previously stored information. All computer systems, servers and personal computers, users can backup storage disks to store and to store information - in case of system failure. Creating a backup system is completely dependent on the operating system on the computer. <br /> <p><br /> <p>1. Press Start. Select "Control Panel". <br /> <p><br /> <p>2. Connect your external hard drive on the computer begin transmitting and storing files on your external hard drive. <br /> <p><br /> <p>3. Click on "maintenance". Choose Save and Restore. " <br /> <p><br /> <p>4. Choose your external hard drive and choose "Configure a backup." A wizard will appear and give you further instructions. While the setup wizard, you can schedule backups, and select where your backup files to save. Under Windows, the recommended storage for backing up files and programs on an external hard drive. <br /> <p><br /> <p>5. Show your stored files by choosing "System and Maintenance" and select "Backup and Restore". On the menu, select "Find files" or "Search" folder to the contents of your backup view. Because Windows will automatically create backup files when it is supplied, you can check or change the scheduled backup for "Schedule backup" to monitor the dates and times for the safety of a system. <br />
on Jun 22, 2011 | Computers & Internet
My Acer 8.9 keeps saying when I turn it on
Yvette,Your hard drive is one physical device but is divided in to two virtual drives. One side is for your data and windows to reside one. The other side keeps the factory defaults for your computer in case you get a virus or your windows installation is broken.
It seems like the restore partition for your drive may be erased, corrupt or damaged. Your other data my very well be okay and can possibly be recovered.
If your laptop came with a restore disk, then you can use that to erase your hard drive and re-install Windows and create a new restore partition.
I would suggest contacting Acer support at 1-800-571-2237 for a restore cd.
Oct 31, 2012 | Acer Computers & Internet
Formatting new sata drive with xp disc but cd dvd roms are not showing in bios
first your cd dvd drives
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
then you should be able to load xp
hope it helps
May 10, 2012 | Intel D865PERL Motherboard
Acer Notebook was getting slow then i try to reset then after the process it restarted then said "Setup is starting services". It shows a error message "The computer restarted unexpectedly...
A scratched cd/dvd can have errors causing the install to fail. Use a clean cd/dvd install disc to fix it.
If you are trying to install directly from the hard drive then a malware infection could have corrupted or damaged that part of your hard drive. Install windows from the cd/dvd disc for your computer.
Aug 28, 2011 | Acer Computers & Internet
Hey i have a HP laptop which is probly a few years old now and i went to turn my laptop on today and the screen would turn itself off just after the windows loading bar finishes loading. i can operate the...
If the Windows installation CD cannot detect the hard drive to install Windows then the hard disk could be faulty or it may only need reseating.
First - remove the hard drive and connect it back into the laptop.
2nd - Boot up the laptop and go into the BIOS configuration and check if the BIOS detects the hard drive.
If the hard drive is detected then proceed with the Windows installation.
If the hard drive is not detected in the BIOS then most likely the hard drive is faulty.
In this case you need to replace the hard drive before you can install Windows.
May 22, 2011 | Computers & Internet
Hi, I have Windows 7 on my MSi L1350 laptop. Whenever I try to play a DVD on my RockSoul DVD Multi Recorder (RW) on Windows Media Player, I get the following error message: "Windows Media Player...
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or
http://majorgeeks.com/Realtek_High_Definition_Audio_for_VistaWin_7_d5513.html
hope this helps
Apr 04, 2011 | Toshiba ROCKSOUL ED100 USB slim external...
I have a Dell Dimension 8400. The hard drive crashed so I went to the Dell website, entered my System Service Tag #, bought the reccomended "compatible" hard drive which is WD 1600AAJS 160 GB...
It will be easier if you will have it checked with any computer technician. They will normally charge a very minimal fee for this very common kind of problem.
Be sure to be there when he checked your computer, so he can also teach you about it.
Mar 02, 2017 | Western Digital Caviar SE WD1600AAJS 160...
Need to install OEM Windows 98
ok you need to reboot your computer from the CD rom with xp disk in it.
start your computer hold down the f12 key, a small menu will come up , pick cd/dvd/cd-rw drive with your arrow keys ,
select enter , follow xp directions on how install operating system on the monitor.
Jan 15, 2008 | Hitachi HDT725050VLAT80 500 GB EIDE Hard...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
