Question about Acer Aspire L100 PC Desktop
Acer Aspire L100 heat problem
Back at the end of Sept, you posted:
"I have a solution for L100 heat problem. My idling temps before fix 55 to 65 cel. After fix 33 to 35 cel. If anyone is interested I will post step by step fix."
My L100 is completely dead and I am wondering if I might be able to resurrect it. I'd love to know what you did
  • 4 Answers
Go into the BIOS and disable the smart fan. The next boot will allow the fan to run at full speed, approx 7200rpm instead of 2800 rpm and the machine will not overheat. However, its will sound like an aircraft on takeoff!
Posted on Sep 20, 2009
  • miffy197 Jan 05, 2010
    I have an Acer L100 and have sorted the problem completely.
    Please be aware that there is ONE fan and it sucks air INTO the computer which then exits through the grilles.
    However I have used a number of fixes and I can't be sure which are the best ones. In order of effectiveness by my reckoning though are:-
    1) In the BIOS turn off the Fan Control.( In System Health) Noisy but immediately solves the overheating problem. Fan now runs at 7200 rpm instead of 2800 rpm.Cost £0
    2) Changed AMD X2 3800 65W ( 2.0GHz) Processor for a 5050e 45W ( 2.6GHz). Cost £55 ( Latest equivalents are XII 240e 2.8Ghz etc)
    3) Cut/drill a couple of small holes in the front left grille in front of the hard drive so air can exit. Cost £0
    4) Switch the hard drive for a 2.5" SATA unit. Cost approx £35.
    5) As the machine was now running almost at room temperature, I swopped the fan for a slower unit that ran at 5000 rpm and made less noise. Speed fan is actually trying to slow the fan down but can't as it is a 3 wire fan, not the original 4 wire.
    All these changes combined have given me a machine where 2 of the 7 or so temperatures on Speedfan are about normal while the rest are cooler than normal. The hottest I see is 44C on one of the MB chips.
    I hope this helps .
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Why, when i try to install driver for vga card in a acer aspire L100 computer, the sistem is shuting down?
    Hi
    thank you for your query
    Please can you try the following
    1) go to www.devicedoctor.com
    2) Download and install the device doctor software
    3) Once installed open it up and click scan, it will then scan your PC for the best driver
    4) Download the driver (entitled VGA driver) and install
    5) Restart and see if this cured the issue
    Regards
    Shauqat
    Jun 02, 2010 | Acer Aspire L100 PC Desktop
    Forgot Acer Aspire L100 BIOS master password. Used "cmospwd /k" to remove password, but power was cut accidentally. Now, machine starts POST (keyboard lights flash), but there is no display.
    In cas eof forgot password of bios you must follow the following steps
    • open the cabinet and look for the bios on the corner
    • there u would find a pin which is fixed on the side of BIOS take the pin out and put it in the next two pins and again fix it at the original p
    Now your BIOS password is reset and u can access your pc
    May 18, 2010 | Acer Aspire L100 PC Desktop
    I have a Acer Aspire L100 and would like to restore to factory settings please help
    If you have lost the automatic restore then you need recovery CD to restore it. To download try this link:
    http://www.user-guides.co.uk/cddownload/Acer/AcerAspire/Acer-Aspire-L100-XP-Driver-CD-Recovery-Restore-Disk-115940.html
    Apr 11, 2010 | Acer Aspire L100 PC Desktop
    Acer aspire l100 12vdc missed
    Is it still under the warrentee?
    if so, let them fix it. if not, open case and cleanout interior with a can of air from electronics store. Especially the FANS and coolers.
    Mastersage........
    Feb 17, 2009 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 overheating
    You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
    Dec 22, 2008 | Acer Aspire L100 PC Desktop
    Go back to Acer.com. The driver you want is the one that say's (Power 1000 chipset driver) that is if it's an integrated Network card. If it's not integrated then I would need the name on the card. Hope this helps.
    Nov 17, 2008 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    1,043 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
