Question about HP LaserJet 4250n Printer
Laserjet 4250dtn Duplex problem
Hi, we have set our printers to duplex as default, via the default printing settings on the server printer driver. A multi-page document prints fine but if a single side is sent, the printers seem to get confused and still try to print the single side as a duplex, thus the single side is actually printed on the reverse and upside-down on a sheet of paper. Has anyone seen this before or knows how to resolve it? Thanks
    An expert whose answer gotĀ voted for 100 times.
  • 87 Answers
How is the printer connected.
Please upgrade the firmware of the printer.
Please upgrade the firmware of the printer:
1. Download the firmware file from the following website and extract it.
Expecting that the printer is connected over the network:
Remote firmware update by using FTP through a browser
Complete the following steps to update the product firmware by using file transfer protocol (FTP) through a browser.
NOTE: The following instructions can be used on Windows or Macintosh operating systems.
Take note of the TCP/IP address on the EIO-Jetdirect page. The EIO-Jetdirect page is the second page of the configuration page printout.
Open a browser window.
In the address line of the browser, type ftp://<IPADDRESS>, where <IPADDRESS> is the TCP/IP address of the product. For example, if the TCP/IP address is, type FTP://
Locate the downloaded .RFU file for the product.
Drag and drop the .RFU file onto the PORT1 icon in the browser window.
NOTE: The product automatically restarts the firmware to activate the update. At the end of the update process, the Ready message appears on the control panel.
The following describes how to upgrade firmware in the LaserJet 2400, P3005 and 5200 Series Printers using a USB connection only.
To send the firmware upgrade via USB, you will need to know the name of the computer the printer is connected to, and the printer will need to be shared.
To find out the name of your computer:
Click the Start button, Programs, Accessories, System Tools, then choose System Information.
You will find your computer’s name in the right window-pane next to System Name.
Write down this name as it will be needed later.
To share the connected printer:
Click the Start button, Settings , then choose Printers ("Printers and Faxes" on WinXP).
Right click on the printer you need to send the upgrade to and then choose Sharing.
On WinXP, if you encounter the following link "If you understand the security risks but want to share printers without running the wizard, click here.", click the link.
Select "Just enable printer sharing" and click OK .
Select Shared As: ("Share this printer" on WinXP) and type a name for the share.
Click Apply and write down the share name as it will be needed later.
To send the firmware upgrade using a USB connection:
Go to a DOS Command Prompt and locate the directory where you saved the firmware file. (To open a Command Prompt inWindows 2000 or XP, go to the Start button, then choose run, then type CMD and hit Enter, in Windows 98 or ME, go to the Start button, Programs, Accessories, then choose MSDOS Prompt). This will bring up a small black screen as displayed below:
If connected to a USB port, Type: copy /b filename \computer nameshare name (for example, copy /b ozfw.rfu \computer1printer).
Press ENTER .
The control panel displays receiving upgrade followed by performing upgrade . The download may take several minutes.
The control panel displays processing job .
The download is complete when the printer reboots and "READY" message is displayed on the control panel.
Posted on Oct 30, 2008
Ricoh 2232 binary bata error on duplex printing
verify you are using the correct driver, there is more than one for that. Other than that check the default settings in the driver.
Jan 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Hi I hv installed hp laser jet 1320 printer in my system but print on both side option is not shown in printer property
Do you have the 1320D or just a 1320. Only the D version will duplex automatically. The base version requires you to manually duplex. If you are sure you have the duplex version, then check the settings in the print driver and make sure it shows that the duplex option is installed. The driver often defaults to no duplexer.
Jul 05, 2011 | HP LaserJet 1320 Printer
Auto Duplex Unit Not Working Model: HP LaserJet 2420dn I am using Windows XP and installed "HP LaserJet 2420 PCL 5e" driver. It is connected via internet and when I try to print double...
You need to go into the print driver on your Windows machine and go to the Device settings tab. One of the settings is to set whether the unit has a duplexer or not. It does not always set automatically.
Jun 23, 2011 | HP LaserJet 2420dn Printer
HP LaserJet 4250 PCL 6 - Cannot get Duplex disabled
Try turning Duplex off at the printer. See if that does what you want.
Jun 23, 2010 | HP LaserJet 4250dtn Printer
Problems with duplex printing
So you're saying it will only pull paper from tray 1? This is likely because there is some setting that makes it think the paper in the other tray is not "normal" -- either thick paper, or a different size, or recycled. Check the paper type and size settings in the printer's menu, and also check the settings in the print driver.
The other tray that you want to duplex from is capable of duplexing, right? On some printers you can only duplex from specific trays.
May 27, 2010 | HP LaserJet 2300 Printer
Print one side only
Plz Check Duplexer Is Disable either thru Hardware or Software
Sep 14, 2009 | Office Equipment & Supplies
How to enable duplex printing in hp laserjet 4250
This unit needs to have a duplex unit installed if you want to duplex. If the back of the unit is "flat" you do not have a duplexer installed.
the duplex unit slides into the back of the printer between the back door and the paper tray. when installed you will have a bulge on the back of the printer about 7 inches tall and the width of the printer that sticks out about 5 inches.
after installing the dupelxer you may need to enable it in the print driver under properties then the advanced tab you should see a spot for advanced settings.
Jun 07, 2009 | HP LaserJet 4250n Printer
HP laserjet 1300n won't print duplex from vista
in the printer driver setting there is option to turn on manual duplex printing.
Go to printer driver properties go to printing default under printing default there is a option called finishing in finishing print on both sides is mentioned select that option and i m sure it should work
May 03, 2009 | HP LaserJet 1300n Printer
Is there away of getting around the paper orientation when I duplex.
This cant be right, if you print on one side, then it is the same as when it prints the first page of a duplex print.
Paper should be face down, head to front for both, make sure you are using duplex driver for your printer and duplex option is ticked. (4250DuplexTwotrayNetwork)\
make sure trays on machine are identified with correct papertype (tray 2 plain and tray 3 letterhead or vice versa)
printer I beleive has setting too enable duplex in print menu.
tray one in manual feeder on these.
When I set these up sometimes I install the print driver twice, ones set to use letterhead and the other plain, so customer can just choose which ever one at print time.
Usally it is set up that you go to driver and select tray or windows decides depending on what doc type is set on what you are printing.
So you need to check settings on printer paper handling and printer menu, you also need to check driver on pc, if on a network you may need to have admin rights to change driver config on server if your system requires it. But you need to check drive has coorect tray/paper type and options too
You also need to check doc type settings on individual document being printed
I have 1000's of customers, running HP (including 4250dtn and this has never been a issue raised.)
Ignore manual, stick letter head in tray 2/3 face down front and print single sided, then use same tray and do it duplex, it will do as the first one did then turn it over and print other side.
I think most customers don't duplex on letterhead, they use that as cover then duplex on plain, but I cant see it not working if you did, otherwise I would of come across it buy now, this machines format has been around for ages and they are great workhourse printers once noisy swing plate gear fault is fixed (common 4250 fault)
Nov 02, 2007 | HP LaserJet 4250dtn Printer
HP LaserJet 4250n Printer Logo
614 people viewed this question
Ben Johnson
