Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Toshiba 42wt29b. screen keeps turning blue
When i switch tv on in morning after a few minutes it keeps turning off with the screen turning blue and no sound and it stays like that for a few seconds and then the picture returns but only for a few seconds. i am really distressed please can you help me. wait to hear from you. i tryed switching tv off from main switch and then back on again but no luck iv tryed to switch sky system on and off but still no luck, iv even changed all the old scart sockets with new ones but no change.
  • 1 more comment
  • riaz ahmed Jun 28, 2006
    any suggestions
  • Anonymous Mar 31, 2008
    I have an older (about 6 years) Toshiba 19" flat screen, not HD. In the morning it takes about 5 minutes of repeatedly turning the set on and having it click completely off until it warms up and stays on. Any ideas other than getting a new set?
  • Anonymous Mar 29, 2014
    It is an HD tv after a few seconds the screen turns blue
    President:
  • 3,130 Answers
MMMM Hard call here. The fact that it does try to come on blue maybe an indication that the power supply regulator circuit is good. It could also be a shorted blue tube and when it comes on its overloading the screen drive and the set goes into overload protection shutdown. The real way to see Would be to pull off the blue crt socket as well as the Hi Voltage lead on the crt and see if the set comes on without blue. If it does Your gonna need a pict tube. If it dosent then troubleshooting along the switched power supplys would be neccassary.. BUT I advise you THAT IF YOU HAVE NO EXPERIENCE TROUBLESHOOTING TV SETS PLEASE SEEK A PRO TO ASSIST YOU AS THERES VERY HIGH VOLTAGE INSIDE THESE SETS EVEN IF THEY ARE UNPLUGGED. GOOD LUCK
Posted on Jun 29, 2006
  • 26 Answers
First, try another video source, such as a dvd or vcr directly into the video input. do you still get the same problem? if so, it is the tv, if not, then it's your sky system (satellite receiver?)
4 Suggested Answers
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
SOURCE: Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Posted on Dec 19, 2008
tvrepairbiz
  • 63 Answers
SOURCE: Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Posted on Sep 03, 2009
I have a Toshiba 50HM66 DLP TV. I turn it on and after a minute or two the screen goes black but the volume is still present most of the time. The picture may come back a few minutes later but go again.The...
I hope our expert would have provided you helpful info in chat session, if you still need further help, let me know the steps taken so far to solve the problem of your tv.
Thanks.
Sep 18, 2010 | Toshiba 50HM66 52" Television
My ' plastic' screen is damaged, can i replace it? i have a 42WT29B
can go to any used tv shop and have them order a new one or you can order one through the company it comes from
Feb 27, 2009 | Toshiba 42H83 42" Rear Projection...
TV Trouble: Toshiba Flatscreen CRT (Brazilian model: Linha Face)
i suggest if you buy it few months ago that item is under warranty
you to call the toshiba service and try to have changed with another
one or get free service - delfo
Mar 21, 2008 | Televison & Video
Blinking red power light - set will not turn on
Were the pale blue lines real thin in a slight diagonal from bottom to top of your screen? If so you either have a bad component in the blue drive, Blue CRT socket or your Blue CRT is shorted.Try removing the blue CRT socket and trying to power up your set for a moment without the blue socket attached to the tube. Be sure the CRT socket doesn't touch any components when you try this. Let me know if the set starts up without the blue.
Jan 23, 2008 | Televison & Video
JVC Projection TV shuts down by itself.
47" JVC TV TURN THE POWER ON THERE ARE SOME BLUE LIGHTS THAT COME ON BUT NOT THE TV. THEN AFTER A FEW SECONDS THE BLUE LIGHTS FADE AWAY.
Dec 15, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba 42wh36p problem
you tv problem intermittent the problem is in the color circuit, vertical circuit.have a tech check your tv for repairs.good luck.
May 18, 2007 | Toshiba 42H83 42" Rear Projection...
Philips wide screen 32in Digital TV
You probably have a component breaking down on one of the circuit boards. It would have to be checked out to find out which one. Stargazer
Feb 13, 2007 | Philips Magnavox 20MT133S 20" TV
TV not coming on...
The same thing happened with my T.V. (although it is an RCA). The first time a repair man charged me $75.00 to fix. The next time we were told to just try unplugging it for a few minutes then plug back in...that worked. T.V. still sometimes does this, unplugging it fixes the problem
Sep 03, 2006 | Toshiba CZ27V51 27" TV
Toshiba TV 20 AF42
need more info but conect the tv direc to the ac outlet and check again...good luck post back
Aug 06, 2006 | Toshiba MD20FN3 20 in. TV/DVD Combo
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
638 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
