Question about Ricoh IS760D Flatbed Scanner
Ricoh IS760D scanner is not showing as a WIA device.
According to Ricoh the IS760D is a WIA compatible device, however only Twain drivers are provided. When I test for WIA compatibility with the wiaacmgr.exe -selectdevice command in window XP I get a device not found message. How can I get this unit running with WIA compatibility?
2 Suggested Answers
  • 394 Answers
SOURCE: I am trying to hook
Hi, I am steve, lets get you some help.
Your scanner only supports TWAIN and ISIS. Whilst you can use the scanner from Windows without any problem you can only control it from an application that supports TWAIN or ISIS.
As you have already discovered your application wants to use WIA - you cannot do this automatically. You may want to check whether your application supports either a TWAIN or an ISIS interface (I would expect it to). This is a long running issue with scanner devices.
You could use the Ricoh software and any TWAIN/ISIS enabled software to import the scans then upload the captured file into the application.
Sorry it can't be simpler than that.
Posted on Jan 17, 2011
Ricoh IS760D won't work with Windows 7 64-bit
Software (driver) can be found at driverupdate us.
Take a look... I hope this was helpful.
Cheers
Jun 27, 2012 | Ricoh IS760D Flatbed Scanner
Please can u tell where i can get a WIA driver download
Hi ,
WIA is included in Windows . Go to "Start \ Devices and Printers " and double click on the scanner's icon . I use a third party free twain program working fine in WIA mode : http://download.cnet.com/FreeKapture/3000-2094_4-10711598.html
You first need to make sure the last valuable original driver/software of your unit is correctly installed , even if it isn't good for W7 or Vista .
Regards .
Jan 31, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
I'm trying to find online driver-software to run an hp scanjet 4470c flatbed in macosx10.4.11, ['m coming up with nothing. help? thanks.
HI
Unfortunately , Hp produces no more drivers beyond OS 9 for this excellent device , and it's a shame .
I managed to make it work under Widows 7 ( same issue , HP has no drivers ) . One of the tricks was to install a third party twain program and make the scanner run with Window's sofware ( WIA ) . I' m not aware of this is possible with Apple .
Installing a virtual compatible OS on primary hdd is another option .
Partitioning the hdd and installing compatible OS on the new partition works also .
I can' t see other possibilities .
Regards .
Dec 07, 2010 | Apple HP ScanJet 3570c Flatbed Scanner
Scanner is not recognizing the TWAIN driver I downloaded
Can you run a test through the scanner and camera wizard?
If so you are using a WIA driver and a registry entry is being blocked.
Look for an error log file in the Epson driver folder.
It may show the entry that has been marked read only.
If so just uncheck the read only mode and re-install software.
Jul 20, 2009 | Epson Perfection 1250 Flatbed Scanner
Genius and Vista
In a communication with the genius scanner manufacturer, their response is pasted below.
I regret to inform you that the vivid 4 is not compatible with Vista.
Airo
KYE SYSTEMS AMERICA
e-mail support: support@genius-kye.com
MSN Messenger Support: support@genius-kye.com
Phone # 305-468-9250 ext: 30
xp.gif< ----------------------------------------They also state that the product specifically states what it is compatible with and does NOT state it is compatible with Vista. :(
Oct 10, 2008 | Office Equipment & Supplies
Genius and Vista
There are two common ways to software-connect scanners
to windows:
1) The TWAIN driver interface
2) The WIA (Windows image acquisition) driver interface
WIA is a driver interface native to Windows:
http://en.wikipedia.org/wiki/Windows_Image_Acquisition
TWAIN is a driver interface specific to each scanner
Most new scanners should support both driver interfaces !
TWAIN is preferable, if you can find it, because it is tightly
coupled to the scanner's hardware design, and therefore offers
more functionality, which is hardware specific.
WIA, on the other hand, is more generic.
It will work with many different scanners, but with reduced
functionality, especially in the tools and setting available within
the scanner control window that pops up every time you try to
scan a document from within an application.
If you cannot find TWAIN, you may have to settle for WIA.
(if it will run with your hardware)
This biggest problem, of course, is VISTA itself, and it comes
in two flavors, depending on your computer CPU:
64-bit and 32 bit.
64-Bit Vista drivers are the hardest to find.
32-Bit Vista is a DOG, because the software is too bloated
to run on a 32 bit machine.
Fancy colors and GUI not withstanding, 100% of the added
"new functionality" within Vista is for the benefit of Microsoft
and the scumbags running Hollywood. Vista hi-jacks your
expensive hardware resources and slows down "YOUR"
machine at "YOUR" expense to promote Microsoft's
insestuous relationship with the Sony movie studios and
the RIAA.
I strongly recommend to all my clients to stick with XP for
now, and avoid Vista like the plague.
I do !
Martin
Jul 12, 2008 | Genius ColorPage Vivid Pro II Film Flatbed...
Ricoh IS760D Flatbed Scanner Logo
630 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
