Question about Panasonic Panafax UF-790 Plain Paper Laser Fax
Panasonic uf-790 keeps telling me that there is no cartridge info code 45
I have tryed new toner cartridges and tryed replaceing the fax machine with a different model but keep getting the same code, any help would be great
thanks
justin.marshall@macys.com
  • jtmarshall Oct 20, 2008
    if you can't read the title it says that i keep geeting an info code-45 no cartridge, i have tried replaceing the toner and have tryed using a different model but still get the same error, i was thinking it could be from the generic tone cartridges
    Sergeant:
  • 284 Answers
Sounds like you have a bent toner sensor. turn the machine off and take the toner out and place on the side
what you could try to do is grab a piece of paper fold it in 4 like so
__ __
|__|__|
|__|__|
then rip one piece off and fold that 5 times over it self.
look into where the toner goes in the middle you will see a silver bracket with a black round piece of plastic on the top left conner you need to put that piece of paper under that coner where the black circle is and turn the machine back on then put the toner in.
if this does not work you need a tech to look at it
Posted on Oct 23, 2008
ERROR CODE 041 ON PANAFAX
There is a fix for this. But only a Panasonic tech has access to the parts for the fix. The toner sensor underneath must be moved closer to the cartridge, you are not low on toner.
Jun 15, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
Code 041
Remove the toner cartridge. Lift up the chrome piece that hold the toner sensor...it's a small black button.
Put a strip of 1/4" X 2" weatherstripping foam underneath.
The sensor is not close enough to the toner cartridge.
Feb 03, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
We have a Panasonic Panafax UF-790
It could be a refilled Kyocera KM-F650 cartridge in a Panasonic UG-5510 box.
They look identical, but are configured differently.
You need to try another cartridge as it appears it is not a machine problem.
Dec 30, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
UF-788 Error Codes...
You have a bad laser unit, no parts are available anymore.
Nov 20, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panafax uf 780
Make sure you have not installed a Toner Cartridge made for the Panafax 585/595 or one for a Kyocera-Mita KM-F650.or Pitney Bowes
It should be UG-5510
The all look identical.
Jul 24, 2008 | Panasonic Panafax UF-780 Plain Paper Laser...
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Drum Cartridge
The drum and toner are all in one cartridge on that product.
You can shake it and see if that will help. But even at that its low and will need replaced soon. Price looks to be about $66.
Mar 25, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Machine will not reset after toner replacement
Info code 45 really means Toner cartridge is not installed.Info code 41 is out of toner & code 43 is toner getting low. There are three connection points inside of the fax machine that tell the machine that a cartridge is installed. Open the cartridge door & remove the cartridge. Verify that the metal tabs on the right hand side above the drive gear stick out far enough to make contact with the cartridge. There should also be two wires that are located on the left hand side that also make contact with the cartridge. Try putting your used/empty cartridge in & see if your info code changes to a 41 or 43.If not, you may have a broken connection. I have found that some compatible cartridges for the panafaxes are missing metal tabs that make contact with the connectors. Compare a cartridge that worked to the one that doesn't to see if it's missing metal tabs. This is not an issue if you are using OEM. Good luck! I can be reached by email if you have any questions. bspier@carlsonsupplies.com
May 23, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-790 Plain Paper Laser Fax Logo
93 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
