Question about 3Com 7760 (3CRWE776075US) 802.11a/b/g Wireless Access Point
Tiscali broadband wireless connection. Router modems last 6/7 wks then won't connect
I've gone through 5 modem routers the last one lasting the longest, Tiscali sent me this one when I extended my contract. It lasted about 3 months but will still connect for about a day if switched off for a day or two. My Belikin is the same but not a sudden loss but more and more frequent connection losses 'till no conection. the other 3 lasted less than 2 months each and have never managed to connect again. All have excellent connection to the router modem from the computer but no connection to the net. I have noticed that when I am connected and the phone rings, I lose connection. Tiscali have been less than useless though they did say my phone line was ok and could support up to 2 mps. I'm sending this from my workplace so dont have the router makes and models to hand. At the moment I'm using the original broadband modem sent by Tiscali, a Sagem 800 this losses connection 3-4 times a night on a good night but on other nights it will run for an hour or so, then won't connect. Hope you can point me in the right direction,
Ceers'
Andy.
  • peterem Oct 31, 2008
    I and others who work at same place have had problems just for last few weeks (since Tiscali changed home page?) where we cannot sync with work VPN/Exchange/Outlook. I also seem to get occasional "freezes" on general internet access. When I go back to the old Thomson speedtouch adsl modem, no problems whatsoever.
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    andy a question..do you have these protected on the power side with any kind of power suppresion or ups?
  • 9 Answers
Hi, have you got filters on all your phone lines, including  a sky box if using one?
Posted on Mar 06, 2009
I have a Dynamode wireless router which i have configured however the cable which came with it does not fit into telephone connection. What other cable do i require
The nework cable that came with the wireless router has RJ45 connectors (8 wire cable) and the telephone cable has narrower connectors RJ11 (4 wire cable) or RJ12 (6 wire cable - less commonly used).
I assume the Dynamode wireless router does not have a built-in modem and therefore needs to be connected to a broadband modem.
If broadband modem is a cable or DSL type, the broadband modem is connected to the Dynamode WAN/Internet socket with a RJ45 LAN cable.
If you have a broadband DSL modem you need a RJ11 phone cable to connect the moden to the phone socket.
Sep 08, 2009 | Computers & Internet
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
ciao
Nov 10, 2008 | Zyxel Prestige 334 Router
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Cable internet setup
No, you need to buy a wireless router and connect wireless router to cable modem. Non cable modems do not work on cabled wireless network.
If you buy cable router, buy either a router with no modem integrated or a modem/router for cable network, this last one may be best option, but it needs to be configured. Ask to retailer which models are ok with your broadband provider.
May 24, 2008 | Computers & Internet
INSTALLING ACTIONTEC WIRELESS ROUTER/MODEM
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | Actiontec GT704WG Wireless Router...
SPEEDTOUCH 576 WIRELESS MODEM driver
HERE is the manufacturer main link to download driver.
page also has manual on installing it and config modem properties.
http://www.thomson-broadband.co.uk/codepages/content3.asp?c=7&ProductID=511
Oct 16, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
4200 speedstream modem problem
I guess you probably aint set-up a wireless router before, what you need to do is get it connected up so you revieve local area is connected then, load internet explorer you will recieve a message like page not displayed. where you usually type in www.ebay.com for example type in the number thats on the bottom of the router ie it looks somthing like this 192.168.1.1 for example. a menu will then appear, fill in your broadband username details etc and you should be up and going, if you have problems feel free to email me,, All the best John Auctionscotland@tiscali.co.uk
Jan 17, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Open Questions:
See all 3Com 7760 (3CRWE776075US) 802.11a/b/g Wireless Questions
3Com 7760 (3CRWE776075US) 802.11a/b/g Wireless Access Point Logo
842 people viewed this question
Top 3Com Computers & Internet Experts
NBX_Tech
NBX_Tech
Level 1 Expert
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
