Question about Tascam Pocketstudio 5 MP3 Player
Pocket studio 5
What exactly did u have to download to get the pocket studio to work.
do u need the installation disc to do this?
This website will have all you need to get this running.
http://www.tascam.com/products/pocketstudio5.html
Posted on May 02, 2009
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
Final Cut Studio Install disc Scratched
I think your out of luck from a legitimate standpoint. If you wanted to go the pirate route you could download a copy from the Web. You would need three items. 1) you would download a Torrent client and install. 2) You would need a torrent file. 3) You would Google the following words "Final Cut Pro or Final Cut Studio 2." Once you have your Google results then you would click on a link and DL your torrent file. Use the torrent client to open your torrent file and start DL'ing.
Aug 03, 2009 | Packard Bell ixtreme 9222 (P491000102) PC...
IBM WSADv 5.1.2 Installation Error
When I installed the Websphere Studio in the past on my system I installed DB2 first; the Websphere Studio was suppliment to the Universal Database. Remember this software was originally compiled for a IBM Unix System (AIX), the Websphere Studio has an integraded Apache Webserver with IBM and Sun Microsystems libraries; it just has been ported to run on a NT Kernel so that developers have access to the libraries. Make sure you have all the install files and the disc is not corrupted; use windows file and folder search targeting the CD drive to see if that binary file is on the disc. If it is on the disc try copying the files and folders to the hard drive; if the disc is corrupted the operation will fail.
Nov 28, 2008 | IBM WebSphere Studio Application Developer...
Panasonic Lumix Simple Viewer & Photofun Studio Viewer software
Do you know where i can download the above software for my camera??
I have this camera, but installation CD with Photo Fun Studio viewer is lost
Aug 29, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Samsung J600
The more you install the worse you're making it.
1. Uninstall PC Studio.
2. Delete all Temp files by doing a Disc clean up, Start/Accessories/System Tools/Disc clean up.
3. Disconnect the USB cable.
4. Do a restart.
5. Download the latest version of the PC Studio for your phone, and the Windows Vista drivers from www.samsungmobile.co.uk. Install both of these.
6. When downloaded and installed do a restart, 2 restarts is recommended. (I've always managed with just the 1 restart).
7. Open PC Studio and follow the directions to connect your phone. Remember that these connections involve a fair amount of CPU thinking, it's not instant, give it time, and it will work.
"Confucius he say: It is good for girl to meet boy in park, but better for boy to park meat in girl."
Apr 20, 2008 | Cell Phones
Pinnacle Studio 10 DVD -NTSC Bonus disc
The installer for Studio 12 (upgrade version) includes a "Transfer Files" option which permits you to install previous bonus discs from Studio 10 and 11 and transfer to 12. However, you have install 12 first (of course).
For those with Vista 64bit systems, Studio 10 will not install on your Vista 64bit OS pc. However, if you have the Studio 10 disc, you can purchase the Studio 12 upgrade version. During the installment process, you will be directed on how to utilize the Studio 10 disc to advance the installation process.
Apr 04, 2008 | Pinnacle Dazzle Video Creator Platinum...
Disc problem
you could try the samsung web site there you will be able to download the studio disc direct to your pc .
Download Center SAMSUNG
riz.
Mar 13, 2008 | Lands Phones
PocketDVD problems
I'm a little confused. Most of the encoding programs I know like Pocket DVD Studio or Pocket DVD Wizard are programs you run on your PC (not the iPaq) in order to create a file which you eventually download to your card and play with Betaplayer.
Sep 11, 2005 | HP iPAQ H5550 Pocket PC
Tascam Pocketstudio 5 MP3 Player Logo
343 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
