Question about Digi 002 Rack FireWire-based Pro Tools LE External Sound System
Digi 002 fader motor doesn't work. - Digi 002 Rack FireWire-based Pro Tools LE External Sound System
  • Anonymous Nov 11, 2008
    I need a source for a replacement fader for a Digi 002 console. I have tried cleaning it.
3 Suggested Answers
fire sine
  • 382 Answers
SOURCE: digi 002 rack
Ive heard the 002 have a latent click after hitting the power button. There was a known fault recognized by digidesign, if the unit is under warranty, call digidesign for support.
Keep me posted.
Posted on Nov 06, 2007
  • 4 Answers
SOURCE: Hi i have digi design rack 002 with pro tools le
Try the other port on the 002. If that doesnt work, I recommend trying the 002 on a computer that does have 400 to see if it will connect then.
If it doesnt, then you may have a couple blown firewire chips inside your 002. It happens, and can be fixed.
Posted on Oct 23, 2010
How to install the drivers for digi 002 on windows 7
Here is the official AVID page regarding the digi 002 drivers: http://avid.force.com/pkb/articles/en_US/Download/Digi-002-003-Drivers
Feb 05, 2013 | Pro Tools Digidesign Digi002 Mixer Avid
My Digi 002 Rack is "Clicking" (the actual unit).
Hi
First thing to do is a hard reset. Merely unplug the power cord for 4 hours, then power up again.In order to dissipated the remaining current stored in the memory and disconnect all unit connected.
Regards:
votit
Feb 08, 2011 | Digidesign Digi 002 Rack FireWire Pro...
Jun 29, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
I want to hook up a an interface to a mackie mixer. What is the common denoinator to hook up, let's say a digi 002 and a mackie mixer so i can have a mac computer with pro tools operational with also the...
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Oct 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
NO AUDIO
Did you solve this problem yet. If not let me kno im looking for a 002 to do some testing plus i need some spare parts.
Feb 11, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi002 faders go down when i open session
Dude.  This is a known problem with the Digi 002 units.  It has a problem with the power harness - which distributes the power to the faders etc.  It's happening to mine as I type.  If your unit is registered, get in touch with your local DD support and let them know.  They'll send out a new harness, instructions on how to install it and contact cleaner - free of charge - after warranty service - due to the fact it's a known problem.
If you can't register your unit for some reason, the gear to buy is around the $70US mark - which I didn't think was too much to get my system up and running again.
Jan 27, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Which firewire cable do I use with my Digi 002 console?
If you are using a desktop comupter, you will need any 6-pin to 6-pin connection. If you are using a laptop, you will need any 6-pin to 4-pin connection.
Jan 12, 2009 | Digidesign Digi 002 Rack FireWire Pro...
Broken Digi 002 firewire port
Did you solve this problem yet. If not let me know im looking for a 002 to do some testing plus i need some spare parts.
Dec 19, 2008 | Digidesign Digi 002 Rack FireWire Pro...
Digi 002 rack firewire
Hey -
Unplugging the harness and reconnecting only worked for a couple days. It turned out that I had to call digidesign and they sent me a new power harness for free. That fixed it for me.
Jun 01, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi 002 rack
easy. Your clock got screwed by one of your audio programs in you system. It Happens when sample rates are mixes up. Leave your digi 002 on it does not set itself other than the factory sample rate setting when primarily switched on, which will remember its last setting if mixed up in an attempt to recover. Leave it on turn your system on. Then turn your system off. Not the digi. just your pc, mac. The software utilizing the previously screwed up sample rate will or should be reset. thus resetting your digi 2 to its factory 44. If it does not work check your software settings for any audio software set as default to run when pc is started ans make sure they are set to play back 44. Never turn your pc off when a program using your digi faulters.
Sep 08, 2007 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi 002 Rack FireWire-based Pro Tools LE External Sound System Logo
165 people viewed this question
Top Digi Computers & Internet Experts
doggzzz
Level 1 Expert
Alun Cox
Don Hart
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
