Question about HP Computers & Internet
Wizard could not start! - HP Computers & Internet
  • michellenina Oct 20, 2008
    o.k thank you for responding ,the wizzard could not start the wizzard/ When i turn on my vista pc. it displays: make sure your audio hardware is working properly,and check your audio configuration in the audio devices and sound themes control panel....... my brother hooked up another modem to our pc and i had to retrasfer the old modem.
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    ok..what wizard are you working with? and also if you do not mind what kind of operating system..xp or vista..
    Master:
  • 538 Answers
Ok..so is it the audio or the modem that you are trying to set up?
Posted on Oct 20, 2008
Hoe to start withouten compaqdisk
You can install windows 7 then should identify components using
SiSoftware Sandra SiSoftware Sandra
Loclise those drivers not provided by Windows, using google and the component.
In control Panls hardware Administrator you can check tohse components with missing driver.
You should check first at HP's website
May 12, 2015 | HP Compaq Evo N1000v Notebook
Setup wizard
Usually the CD only contains info about the router and is not used to set up the router. What you need is the manual so you can login to the router. Once you get in, some routers will detect first time login and start a wizard which will help with the configuration. Others you have to navagate to the wizard and start it yourself.
Jan 19, 2014 | Edimax BR6204Wg Wireless Router
Activation wizard
Choose License transfer utility from the start menu->Autodesk->Name of the software. It should open activation wizard.
Re-install the software.
Oct 05, 2013 | Autodesk Computers & Internet
Asus preload wizard
Try a system restore, take computer back in time before this happened. Go to start menu, accessories, system tools, and system restore, you can reverse it back if this fails to work.
Jun 04, 2012 | ASUS Computers & Internet
How to change my password in wifi?
You can configure the router by running the Setup Wizard in the
CD-ROM provided in the package. The wizard provides quick setup
for the Internet connection, SSID, wireless security, firmware
upgrade and changing router's password. When you start the
Setup Wizard, you will get the following Welcome screen. Please
choose the language to start with and follow the easy steps in the
Wizard.
Manual Below:
http://www.edimax.co.uk/images/Image/manual/Wireless/BR-6226n/BR-622xN_Manual.pdf
May 10, 2011 | Edimax BR-6226n nLite Wireless Broadband...
How do i install this?
  • Place the product installation CD in the CD drive of your computer. The installation wizard will start automatically. Follow the installation wizard prompts.
  • Plug the USB connector at the end of the LifeCam VX-1000 connection cable into an available USB port on your computer when prompted.
  • Place the LifeCam VX-1000 on a flat, level surface, or hang it from your computer's monitor. Continue following the wizard prompts until the installation wizard finishes.
  • Click the "Start" button, then click "All Programs" on the Start menu.
  • Click the "Microsoft LifeCam" folder icon in the list of programs on the Start menu, then click the "LifeCam" icon. That opens the LifeCam VX 1000 software and completes the installation process.
  • Dec 23, 2010 | Microsoft LifeCam VX-1000 Webcam
    Enable wap and sun internet in nokia 6730
    Settings à Sett. wizard
    Use Settings wizard to define e-mail and connection settings.
    The availability of the items in Settings wizard depends on the features of the device, SIM card, network operator, and the data in the Settings wizard database.
    To start Settings wizard, select Start.
    To get the best results when using the settings wizard, keep your SIM card inserted in the device. If the SIM card is not inserted, follow the instructions on the display.
    Select from the following:
    ? Operator — Define the operator-specific settings, such as
    MMS, internet, WAP, and streaming settings.
    ? E-mail setup — Create a new mailbox.
    ? Video sharing — Configure video sharing settings.
    The settings available for editing may vary.
    Apr 09, 2010 | Nokia 6730 classic Cell Phone
    Does the 2002 wizard live have a diesel option.
    my diesel isuzu wizard is shaking when i start it till i drife it above 40km/u
    Apr 10, 2009 | 2002 Isuzu Trooper
    This version of Windows does not support this version of Roxio DLA. This product, which was created by Roxio, Inc., has been blocked from running because it might keep your computer from starting correctly...
    Getting older programs to run on Windows XP Getting older programs to run on Windows XP Most programs run properly on Windows XP. The exceptions are some older games and other programs that were written specifically for an earlier version of Windows. To run your program on Windows XP, try the following:
    1. Run the Program Compatibility Wizard. As an alternative, you can set the compatibility properties manually.
    2. Update your program, drivers, or hardware.
    These options are covered in detail below.
    The Program Compatibility Wizard This wizard prompts you to test your program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows 95, set the compatibility mode to Windows 95 and try running your program again. If successful, the program will start in that mode each time. The wizard also allows you to try different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
    If compatibility problems prevent you from installing a program on Windows XP, run the Program Compatibility Wizard on the setup file for the program. The file might be called Setup.exe or something similar, and is probably located on the Installation disc for the program.
    To run the Program Compatibility Wizard
    1. Start the Program Compatibility Wizard.
    2. Follow the instructions in the wizard.
    Dec 19, 2008 | Computers & Internet
    Toy Story Interactive Incompatibility
    You could try this.
    clip_image001.gifNote
    • To start the Program Compatibility Wizard, click Start, click Help and Support, click Find compatible hardware and software for Windows XP, and then, under See Also in the navigation pane, click Program Compatibility Wizard.
    To set the compatibility properties for a program manually
    1. Right-click the program icon on your desktop or the shortcut on the Start menu for the program you want to run, and then click Properties.
    2. Click the Compatibility tab, and change the compatibility settings for your program.
    clip_image001.gifNotes
    • The Compatibility tab is only available for programs installed on your hard drive. Although you can run the Program Compatibility Wizard on programs or setup files on a CD-ROM or floppy disk, your changes will not remain in effect after you close the program.
    If this doesn't work you will not likely be able to play them.
    Nov 12, 2008 | Computers & Internet
    Computers & Internet Logo
    46 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
