Question about HP Office Equipment & Supplies
I have a hp scanjet G4050. cannnot use the copying a document portion of my scanner. I have uninstalled and reinstalled, but the when I press the the copying button I only get scanner and camer wizard. What do you suggest? Ed.
  • Puneet Jain
    Puneet Jain May 11, 2010
    Have you installed the correct drivers. Have you got the installation cd with Printer.
    For more useful info regarding Troubles in Installation please have a view on this:
    Driver and Installation of Printer
    Guru:
  • 558 Answers
Is your printer problem solved or not.. let me know the status so that I can help you out.
Otherwise please do vote at least helpful .. Have a Nice Day.
Posted on Oct 24, 2008
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
G4050 scanner top glass cleaning
Go to the following link for full instructions
Jul 26, 2014 | HP Scanjet G4050 Photo Flatbed Scanner -...
Unable to scan from front pannel button on HP G4050
try scanning by conneecting it to the computer and installing the program of the scanner then you will be able to do it from you computer
Feb 27, 2013 | HP Scanjet G4050 Flatbed Scanner
HP ScanJet asking for DPE
Where is DPE? - When I tried to save a pdf-file (black/white), I was asked this question and my application folder opened automatically. I am using Mäc Leopard and hp g 4050 scanner. Who can help me solving this problem? I don't even know, what DPE means. Martin (Morogoro-TZ)
Nov 15, 2009 | HP Scanjet G4050 Flatbed Scanner
How do I get my computer to detect my HP G4050 Scanjet. I keep getting an error message that ''No HP product has been detected and Solution Center will now close''.
First you have to download and install scanner drivers, then your system will know it has a HP scanner attached.
Go to HP.com website, choose support and drivers, enter your model and choose a driver for your operating system. Download and run the downloaded file to install the driver, and plug the scanner in when asked to by the installer.
Nov 08, 2009 | HP Scanjet G4050 Flatbed Scanner
Cannot uninstall or install HP scanjet G2410
I tried all the "decent" uninstall solutions like running HP's Level 1-4 Uninstall batch files. HP's installation software still insisted that parts were already installed. Then, with the scanner connected, the installation software got into competition with Windows also trying to install the driver. The reinstallation was no good. Solution Center wouldn't even start, preposterously announcing that it couldn't find the scanner!
When you have a reliable clone of your c:\ drive you can try daring solutions. Such as this:
1. Search the c:\ drive for files and folder with "Hewlett" or "HP" in their names. Kill them all.
2. Search the registry for keys with "Hewlett" visible or buried. Kill them all.
After 1 & 2, reinstallation worked smoothly. And my computer still works! The only evidence of the violence is an undeletable file 3963d.rbf now in c:\Config.Msi. I will report back if serious computer problems arise.
The point is that manual uninstall is possible and none of the elements are in hidden places. Someone else can determine whether both file and key deletions are necessary and exactly which ones.
Apr 08, 2009 | HP Scanjet 4470c Flatbed Scanner
Scanner not found HP scanjet G4000 series
I cannot uninstall my software, I need to do a complete reinstall to try to rectify problems
Jan 09, 2009 | HP Scanjet G4050 Flatbed Scanner
HP ScanJet G4050 won't work in Solution Center program
Hi Jankatie
You need to unplug the scanner cable from both the ends and then reconnect it back make sure the power is disconnected,
then reconnect the power too
Uninstall the existing software from add remove programs in control panel
reinstall the whole software with the cd you got with the scanner'
once the installation is over it should work fine
Its the driver software corruption which is creating the problem.
for further assistance please post here
Regards
Jun 24, 2008 | Office Equipment & Supplies
Horizontal Lines
This might be a hardware problem, but it could also be caused by an outdated (or corrupted) driver; you could uninstall the original driver, then download and install the newest version directly from HP here:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=446435&lc=en&jumpid=reg_R1002_USEN
If that link is broken, or doesn't work for you, use this one:
http://tinyurl.com/2n7lge
Also, I've copied the following information directly from the HP 4850 Scanjet user's manual:
If you have the HP Image Zone software installed, you can use the onscreen Help to solve other problems with the scanner. To gain access to the Help, open HP Solution Center, click Help, and then click HP Scanjet 4800 series scanner Help. The Help system provides information about the HP Scanjet 4800 series scanner hardware as well as information about the HP Image Zone and HP Scanning software itself. Also, see Scan troubleshooting in the general Troubleshooting and support section of the Help.
Good luck with this; let us know what you learn...
Jan 26, 2008 | HP Scanjet 4850
Seeker5211
Seeker5211
