Question about Hoover S3614 Vacuum
Hoover Vacuum My Hoover cannister model s3614 "runabout powermax" suddenly lost power to the agitator roller in the rug brush. Where the wire cord enters the power brush, the covering has rubbed off exposing the wires which are not bare but still have their own covering. For a while the power came and went as I manipulated the wires but finally died. Is this something I can fix myself or is it going to be an expensive professional repair? (Warrantee has elapsed.) Thanks.
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Posted on Feb 13, 2008
I thought it was the belt too. The one one on the brush was loose. I replaced it with exact one (numbers were still on old belt)...and new belt is still loose. Brush/beater does not spin....and I can see that belt is very very loose. I am wondering if the "channel" on the brush gets worn..or the something can be tightened. thanks Bill
Posted on Jan 11, 2007
I have no owners manual and need to replace the belt on a Hoover powermax model #:U5242-930 can you help thanks Bab
I don't see this unit on the Hoover support site. However other Powermax vacuums come up in the search for manuals: http://www.hoover.com/CustomerService/manuals/Default.aspx .
Most of the units have very similar belt replacement procedures. First unplug the vacuum. Then press the handle release lever and place the handle in the low position. Next remove the hood by turning the two slots either side of the hood with a coin. Rotate the hood towards the front of the unit and remove it. Then remove the agitator brush roll and the old belt. Discard the old belt.
With the lettering to the outside, slide the new belt over the motor pulley. (The old belt should have been on the pulley. If the belt broke and isn't in place, look for it on the right as you look at the front of the vacuum above the agitator brush roller's position.) Slide the agitator brush roller through the belt and place the belt in the belt guide on the roller. Grasp the agitator and put it into position. Fit it into the rectangular slot on the left. Then pull it into position on the right side of the vacuum. Check if the agitator and the belt turn freely and that the belt isn't pinched between the agitator and the bottom of the unit. Replace the hood by aligning the tabs with the slots on the base. Then turn the coin slots to secure the hood.
I hope this helps.
Feb 01, 2011 | Hoover Powermax U5242-930 Vacuum
My Vaccuum Hoover U5763-900 wind tunnel Twin Chamber is barely used. Belt is in tact and agitator is not worn. Nothing clogged. Agitator spins fine off the ground or on hard surface or flat rug. Once on...
It's because the belt is stretched out and has lost elasticity. It can turn the brush in the air but is not tight enough to turn it in the carpet. Replace the belt at least once per year even if the vacuum is never used.
Feb 09, 2018 | Hoover U5753-900 WindTunnel Bagless...
How to replace Hoover PowerMAX power nozzle cord?
You can get the new cord at your local vac shop or you can take the power nozzle to the shop and have it repaired
Apr 27, 2017 | Hoover Powermax S3601 Bagged Canister...
Where does the piece go to rise and lower the brush
HI There,
The part that raises and lowers the height adjustment goes underneath of the hood on the vacuum cleaner, and is held on by the carpet height adjustment know on the top of the hood.
I've done a repair below that explains how to get the hood off of the roller brush housing, and replace the knob next to it which is the rug/floor selector knob which is the one right next to the height adjustment part. The repair on your machine will be the exact same process however. Hope this helped you:
If you've already changed the belts and the machine still won't run, it can really be only a few things.
The first thing you should check to make sure that the roller brush is good. You may do this by removing the bottom plate, and then taking the roller brush out of the vacuum2_bing.gif. Hold the bar using just your fingertips on the very ends of the brush on the bearing caps. With just holding the bearing caps with your fingers, use your thumbs to try and spin the bar. Does it spin freely without any resistance? If no, then you'll need to replace the roller brush. Here's a direct link to the exact roller brush for your Hoover Windtunnel Self-Propelled:
Hoover Windtunnel Agitator Brush Part # 48414069
If the roller brush spins freely several times on each spin, then your machine may possibly have a bad Rug / Floor actuator arm. This part controls the internal pulley that stops the roller brush when you turn it from carpet to floor mode.
I'm guessing that this is probably a more likely cause of your brushes not spinning. Here's how you can check this part:
Step 1. Make sure that the vacuum is unplugged. Turn the machine upside down so that the brushes are facing upwards. I find the easiest way to do this is to put the brushes on top of a counter top or work bench with the handle of the vacuum resting on the floor. Remove the four screws that hold the bottom plate in place. Remove the bottom plate, both belts and then the roller brush from the machine:
Step 2. There are 3 screws that hold the top brush cover in place that need to be removed. On the right side the screw is down below the transmission to the right. There's also a screw in the agitator tray, in the middle that needs to be removed. NOTE: This small screw in the agitator tray is only present on some models, you's may or may not have this little screw, but all models will have all other screws circled. I have circled both screws that need to be removed:
The screws on the left side that need to be removed are also circled. One screw holds the upper brush cover on, and the other two screws secure the hose in place. Remove all three screws as well as the transparent hose cover:
Step 3. After all of these screws have been removed, there are two clips that are the last things holding the top brush cover onto the vacuum. Use a flat head screwdriver to push these clips off on both the left and right sides. The right side clip is near the pulley that the flat belt2_bing.gif rides on, and the left side clip is next to the internal hose.
Step 4. Once both of these clips have been pushed so the unhook from the lower agitator housing, remove the top cover. On the top you'll see two selector knows, one for the height adjustment, the other that controls the rug / floor setting. Turn the cover over and look at the opposite side of the knob that controls the rug / floor selector. There should be an arm that extends out that looks like this:
Sometimes this arm will break off, which will prevent the actuator arm from activating the rug carpet setting. The machine basically will always be set to bare surface floor mode. Is this arm broken off on yours? If yes, then here's how you can remove it from the machine.
Take your flathead screw driver, and place it underneath of the of selector knob on the top of the cover. Simply lightly pry upwards to separate the knob from the arm underneath:
Replace the actuator arm with a new one and see if this fixed your problem. If this was not the problem, there's really only one other possible thing it could be, but I rarely see this go bad. Please let me know if this fixed your problem, or if it is something else wrong. I'll be happy to then walk you through the last remaining possible problem.
I really hope that this repair was helpful to you. If you did find it to be helpful, help other Fixya users with the same problem find this repair by rating it helpful. You can do this by clicking on the thumbs up icons in the top of the repair.
Thank you very much,
Chris J.
May 02, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover Wind Tunnel U6437-900. The brush will not turn. I have replaced both of the belts with no success. Any suggestions?
The first thing you should check to make sure that the roller brush is good. You may do this by removing the bottom plate, and then taking the roller brush out of the vacuum. Hold the bar using just your fingertips on the very ends of the brush on the bearing caps. With just holding the bearing caps with your fingers, use your thumbs to try and spin the bar. Does it spin freely without any resistance? If no, then you'll need to replace the roller brush. Here's a direct link to the exact roller brush for your Hoover Windtunnel Self-Propelled:
Step 3. After all of these screws have been removed, there are two clips that are the last things holding the top brush cover onto the vacuum. Use a flat head screwdriver to push these clips off on both the left and right sides. The right side clip is near the pulley that the flat belt rides on, and the left side clip is next to the internal hose.
Chris J.
GoVacuum
Apr 04, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
Brush roller does not rotate around
If the rotating brush doesn't turn, then it's almost a certianty that the belt (which connects the rotating brush to the motor pulley of the vacuum) is either horribly stretched or just plain broken. Either way, it needs to be replaced. The correct Hoover belt part # for your vacuum is 38528040 (changed from the original part number of 38528027). This is a very common Hoover belt, but would recommend your best source as being a local, independently-owned vacuum dealer dealer (as opposed to a deprtment / big box store, both of which carry very limited belts).
May 03, 2009 | Vacuums
Bottom roller bush does not spin
Sounds as if the v-belt came off the idler arm or you broke the v-belt. Either way, take the 4 screws out of the plate around the roller brush and make certain the belt is there and that it sits on the idler wheel. If you remove the roller brush you'll see the wheel. Pay attention to how the ends of the roller brush go back into the vacuum when inserting it and put the plate back on. Also check the thicker main belt is in place as well, it's to the left of the v-belt.
Also, the roller brush should stop when you put it in the upright position. Next time just stand it upright so the throw rug doesn't get drawn quite so far into the vacuum.
Dec 19, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
My hoover vacuum spits out dirt particles as I vacuum!
the vacuum is clogged somewhere the brush roller is just kicking stuff around, as it cant get into the suction port
Aug 25, 2008 | Hoover S3614 Vacuum
Hoover Vacuum correction
I don't know what is your experience with wire's soldering, but you should remove the insulation from the damaged wire and solder the disconnected edges. Then wrap an insulation band on the repaired wire first and then on all the other wires. Be aware power cable is disconnected !!!! If you can't do it by yourself - repair cost for it should be very cheap. Good luck !!
Jun 28, 2006 | Hoover S3614 Vacuum
Hoover S3614 Vacuum Logo
982 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
