Question about Brother EM-530 Typewriter
Repeat printing How do I program something I have typed so all I have to do is hit a certain key for it to print again.
  • 328 Answers
Go to brother usa.com and download a user manual.
Posted on Oct 31, 2008
Lexmark Pro 715 prints garbage
Sorry, hit the wrong key... IF a different program prints okay, try again with the program that invoked the original issue.
Update windows and the offending program.
The piece that stumps people is the buffer. Print buffers sometimes do not purge easily, and you have to "bleed" the garbage out of the buffer, by turn off, and back on type of procedures.
Oct 05, 2012 | Lexmark Pro 715 All-in-One Printer
My Toshiba Satellite P755-s5320 letters and number will not work. Even the number pad on the right side won't work, and yes the num lock is on. I'm thinking my cat may have pushed a button or...
Yes you are correct the print box is displayed when Ctrl + P are pressed. When the Ctrl button is held down one will not be able to type numbers at all.
I think your Ctrl button is stuck, try pressing it repeatedly to unstick it.
Worst case you will need a new keyboard.
Take care!
damnor01
Sep 11, 2012 | Computers & Internet
Dell V715w all-in-one print job stuck in que
Go to your search programs and files box in the start menu and type in services when you open services scroll down to Print Spoolers double click and you will see service status started hit the key that says stop after it stops hit OK to close it and reopen Print Spoolers and click open tab and then hit OK to close then close services box and you should be able to print again.
Good Luck
Aug 16, 2012 | Dell All-in-One Multifunctional (v715w)...
HP Deskjet 1000...will not work. Screen says "print spooler not running". It also will not allow me to uninstall the printer. Any suggestions?
HI welcome to Fix Ya.
It sounds like the print spooling service in Windows is not running. This is easy to remedy. The first thing you need to do is start the service. The easiest way to do this is:
1. Go to Start and type "cmd" in the search box. This will bring up the cmd program (command prompt or DOS prompt). Right click on it and select "Run as Administrator."
2. This will bring up the Command Prompt window where you will see : C:/Windows/ system 32> "type" net (hit spacebar) start (hit spacebar) spooler (hit enter key)
3. Underneath the command you just typed, you will see the words:
"The Print Spooler Service is starting..............."
" The Print Spooler Service started successfully."
4. At the command prompt, "type" the word, exit. Then hit the enter key. This will close the program. So, it will look like this:
C:/Windows/ system 32>exit
Once you start the print spooler service, turn your printer on. Then, go to your printer's properties in Windows by going to :
1. Start> Devices and Printers>Click on it to open the window.
2. Select your default printer>right click on it and select printer properties.
3. After the printer properties window opens, click on print test page.
This should resolve the problem. Should you need further assistance, leave a comment below and I will be more than happy to assist you further. Thanks for using Fix Ya.
Jul 11, 2011 | HP Office Equipment & Supplies
When I goto print something, it just does nothing. When I check the print queue, the document is there and restarting does nothing. When I goto the printers and devises it shows the printer as...
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Jul 02, 2011 | Office Equipment & Supplies
I can not open my print screen..what will i do??
In order to do a "Print Screen, hold down the Shift Key and Hit the "PrinitScrn" key. Open Paint or some other graphics program and go to edit and paste the image. This will paste the print screen to the graphics program and you can then edit, print or manage the print screen any way you desire. Let me know if you require additional assistance.
Jun 13, 2011 | Acer Computers & Internet
How do I program the typewriter to repeat?
First be sure the batteries are good.
On the L. side of the keyboard are 3 keys store, play and delete.
Hold the store type an address 01-99 type info press store again.
To print hold play plus the address.
DickyO
Dec 20, 2010 | Lexmark Wheelwriter 3500 Typewriter
Print screen key on computer.
On a windows computer by hitting print screen you are only copying an image of your computer screen to your clipboard you then have to paste it into an imaging program and save it. For example ... hit the print screen button on your keyboard -> go to start -> programs -> accessories -> paint -> then click the edit menu and click paste you should then see the screen shot of you computer in the paint window you then can go to file -> save and save the image somewhere on your computer.
Mar 22, 2009 | E-Machines eMachines Desktop PC
Print from memory
put mach. in NP mode
press the PRINT key ("name of file" should appear)
type the name of the file and hit RETURN key
then hit RETURN again
Sep 29, 2008 | Nakajima AE-740 Typewriter
Brother EM-530 Typewriter Logo
60 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
