Question about Epson Stylus Photo R2400 InkJet Printer
Epson r2400 won't feed paper
Hi-- I have an epson r2400, and it won't feed matte paper in any way. I tried adding the extra piece for matte paper, I tried manual feed, sometimes it grabs the paper but just sends it through, and then I get the same message as always: Paper not loaded correctly.
Anyone have this problem?
  • 2 more comments
  • bgreenspon Nov 09, 2008
    I have the same problem, whatever paper I use. Every so often, rather rarely, it sends one page through to print beautifully. I can't get it to print, though when I press the paper button, the paper comes through. Other times, the paper may begin as if to print, but the minute it gets taken up (feed), it then comes through blank.
  • Anonymous Jan 21, 2009
    how do you reset the printer?
  • Anonymous Jan 29, 2009
    exactly the same, feed problem, wont take normal paper, have to hand feed many times till it takes it. drives me nuts.
  • Freddie5o Feb 05, 2009
    I have the same problem. How do you reset the printer? The highlighted word "printer" in the answer below takes you to an ad for HPprinters. Not useful for a photographer.
I had the same problem, then found these instructions for cleaning the feed roller: http://www.museofineart.com/files/RollerCleaningProcedureRev2.pdf I used the paper towel method and it's working fine now with no issues.
Posted on Mar 06, 2009
    Problem Solver:
  • 4 Answers
Insert more then one sheet of paper a tthe time and this will solve your problem.
Posted on Feb 02, 2009
Thanks Lulen,
I had the same problem, and I followed the link for cleaning the rollers and it works! But I think the link has been change. Try this:
http://www.museofineart.com/index.php/technical-support/
Posted on Feb 05, 2014
  • Epson Master
  • 541 Answers
You may need to reset the printer
Posted on Nov 17, 2008
Paper feed jams on right hand side after I pulled bits of an A4 that came out ripped
Bruno:
You did not get all the pieces of that A4 paper out of the paper path. There is still a small shard of paper in the right side of the paper feed area. Use a flashlight to look carefully in the paper feed area and gently use tweezers to remove the piece of paper. If you pulled the sheet of A4 paper backwards out of the feed area, you may have dislodged the paper feed sensor (a small plastic finger that sticks down in the paper path to tell the printer that the paper has passed.) Be careful with the tweezers... if you break that sensor, there is no fixing it.
Jun 21, 2015 | Epson Stylus Photo R2400 InkJet Printer
Paper doesn't feed properly R2400
You may have a paper jam. A small piece of paper in the rollers will cause that. Open printer and look for any paper in between the rollers, pull it out.
Feb 05, 2014 | Epson Stylus Photo R2400 InkJet Printer
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
My printer will not grab the paper
I have an R2400 and it is very finicky about grabbing the paper. I have to hand feed sheets of thick matte paper one at a time with just the right amount of pressure and even then sometimes it takes two tries. Make sure you keep the rollers very clean.
May 04, 2010 | Epson Stylus Photo R220 InkJet Printer
Epson R2400 does not display all the paper types available, currently only a small number. Why is this please?
It depends on which Black cartridge you have installed. For Glossy Photo papers the Photo Black (PK) needs to be in the printer. For all other papers to appear then you need to change it to the Matt Black (MK) cartridge.
Jan 26, 2010 | Epson Stylus Photo R2400 InkJet Printer
How do i print labels using epson r2400 photo printer?
If you are using the Avery template, make sure you change the page setup settings from Manual Front (default) to Default Tray (sheet). Then when it tries to fix the layout, select ignore (on Wrd 2007 anyway). Then select Photo / Glossy paper and hopefully away you go.
Mar 31, 2009 | Epson Stylus Photo R2400 InkJet Printer
Print head alignment +won't feed paper
Best solution is to clean the head with it in place,here's
the manual for your printer
Oct 09, 2008 | Epson Stylus Photo R2400 InkJet Printer
Epson stylus k3 r2400
Hi Lisa
The R2400 has the choice of two black inks, MK and PK. One is for Matt printing, the other (called photo black) is for gloss.
If the printer has the matt cartridge fitted it only allows suitable options, including paper choice, to be selected. If you change the black cartridge from the MK to the PK one, you should then have the choice of gloss paper.
Rich
Oct 04, 2008 | Epson Stylus Photo R2400 InkJet Printer
Epson Stylus Photo R2400 InkJet Printer Logo
2,371 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
