Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Poor cable connection
I have a Sony K?-32? Trinitron 16:9 tv I purchased about 8-9 years ago in Hong Kong. The cable connection is a type of RCA connection that is standard in Hong Kong but requires an adaptor to attach a North American threaded fitting. I find my reception from cable is poorer than another TV in the house and I always have to reposition (jiggle) the connection to clear reception (snow?). Even at best reception picture and colours are not as clear and sharp as other TV's in house. Picture from DVD player is much better with some DVD's producing an excellent (although not as good when new, I think)picture. Can the connection be changed to North American type? Is this something I can do at home? Other suggestions to improve reception? Thank you.
  • Anonymous Mar 24, 2014
    Reception is good but the sound doesnt work
  • 26 Answers
Radio shack sells type f/rca adaptors
Posted on Jun 28, 2006
What is the code for my Sony Trinitron Wega 32" TV using a RCA RCR311 B universal remote?
Try this
http://www.retrevo.com/support/RCA-RCR311-Universal-Remotes-manual/id/402ci569/t/2/
Aug 29, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How much is PSP in hong kong
There is no direct re-seller in Hong kong but you can at least get some idea from this link PSP price in Hong Kong - Hong Kong GeoExpat.Thanks for visiting fixya
Sep 28, 2011 | Sony PSP-3000 Black Console
Hi, I have a sony bravia tv ( klv20G300A) which was bought in Hong Kong about3 years ago . I haven't been able to get it to work with the uk digital signal. I am wondering about it's compatibility-...
This tv has analog tuner and you need digital tuner in tv to get digital signal in UK, alternate way is to hook cable box with this tv that will convert digital signal into AV output that will connect to AV input of tv to get cable channels.
Aug 03, 2011 | Sony BRAVIA KLV20G300 20 in. EDTV-Ready...
No problem, wondering if I'm able to connect this TV to my laptop to connect to the internet and if so what do I need to do this.
Yes, you should be able to. You will need to buy a $20 adapter. Sewell Direct sells them, also Amazon.com. They are called VGA to RCA composite video converter. This will convert your laptop's VGA output to RCA composite video for connection to your TV yellow video input. Connect an audio cable from laptop's earphone output to the TV's RCA audio inputs (white and red) using a 3.5mm to RCA adapter cable available at Radio Shack for about $10. This will work. You can see everything that the laptop displays on the TV. You can even hookup a VCR to record it all.
Aug 04, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My sony trinitron wega says no signal when I connect the coaxial cable.
Your Sony has several varieties of possible connections.
They include,
  • HDMI (High-Definition Multimedia Interface)
  • Component video
  • S VIDEO
  • Composite video
  • RF/Coaxial
Make sure that the appropriate choice with in the menu "SETUP" option matches the connection at the rear.
If this is done correctly and you still have now picture it may be an issue with the cable or the connector on the end. Check the tip to make sure that there is between 1/8 to 1/4 inch of the internal wire past the end of the connector.
If this looks ok try a different hook up such as the "S-VIDEO" cable and seperate left and right audio "RCA" cable.
If you have no image after trying one of the other connection types then the issue may be with the TV itself which would require servicing.
Hope this helps
Oct 07, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
No listing of 3 digit codes for Sony Trinitron, RCA universal rem
  1. Turn TV on.
  2. Press and hold TV button and Power button until light stays on.
  3. Release both buttons.
  4. Aim remote at TV and press the power button every 5 seconds until TV turns off.
  5. Press stop button at bottom of remote.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No Color image - B&W image is distorted
it could actually be the cable box itself or there could be corossion on the cable connection outside
Dec 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV XA 21M80 Trinitron- HUMMING NOISE AND PICTURE NOT CLEAR
If your set has a humming noise when connecting the cable, call your cable company. There is a ground issue. This can also be a safety issue.
If your signal is PAL, and your TV is NTSC only, you will have to replace the TV with a PAL one in order to properly view the programs.
Jerry G.
May 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 32" trinitron kv=32fs16 tv problem.
I had the same problem 3 years ago. I called in a Sony tech and he said this was a common problem with this model. He replaced several resistors and resoldered several "Coaled Solder" connections. The repair ran $187 but the set has run great ever since!
Oct 17, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
179 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
