Question about Dishwashers
Diswasher siphon blocked
our diswasher stops halfway and displays "20" flashing !!!!
according to manual the siphon maybe blocked!!!
can nanyone tell me where the siphon is located????
AEG want £ 115 for a call-out!!!!
thank you
Chris
  • xamolaml Nov 25, 2008
    sorry, 1st time user of this site. i have the same problem-where is the siphon on the aeg-not mentioned in the instructions-thx
I have the same problem
Posted on Nov 25, 2008
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
My dishwasher is allowing the water to enter then it will wash for 1 second, then it stops and the red light is not flashing.
What brand is it ? Also most diswashers have a float switch that tells the control panel that the water level is at the operating level. These floats get stuck sometimes and can effect the operation of the diswasher.
Oct 11, 2010 | Dishwashers
After 6 years of once-a-day family use my AEG OKO_FAVORIT 6281i dishwasher starts up OK but a few minutes into the cycle begins flashing error code 20. At this stage there's a litre or two of cloudy water...
The easiest way to empty the dishwasher would be to use a small container and empty most of the grubby water. Then take a towel or two and dry it out.
Now about the error code - does it come back when you turn the power off and on again?
Jul 02, 2010 | AEG Dishwashers
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Miele Incognito G843SCVi Plus diswasher will not drain
if the timer is in good condition (no wires burned off)  then it must be the pump itself that need replacing  dishwashers need the drain hose to rise to the counter and then fall again to siphon and make the pump work easier  also it helps keep water in it to stop the plastic parts in it from overheating    if the hose doesn't rise and fall  it may have led to your failure
Nov 07, 2009 | Miele 24 in. Incognito G843SCVi Built-In...
Every time I pump gas with high pressure, the pump just keep ejecting. The tank is not full yet. Do you know why is that?
it could be your intake line is constricted or the anti-siphon device is splashing the gas enough for the pump to trigger. On the pump nozzle, there's a sensor somewhere near the tip that detects when there's enough pressure from the gas to shut the pump off. If you pull the nozzle out halfway and pump, it should reduce the chances of the pumps from stopping
Sep 18, 2009 | 1998 Honda Accord
Blocked drain message on GE GSD2800 dishwasher
pull the bottom tray out, in the back portion of the center of the dish washer there is a plastic screen looking thing, you will need to take a 1/4 inch nut driver and take out the screw pull off the cover and clean out the drain,, there is probly some food particals in there , it does havea small blade inside there to help sut up fine food that gets thru but it doesn't do it all the time ,, make sure you put the cover back on before runnig the unit
Jun 27, 2009 | GE Profile PDW8400J Built-in Dishwasher
E4 error message
take off two black covers on bottom front of machine and mop up or soak up any water you feel or see at very bottom of machine by a polystyrene float this will fix it
Dec 27, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Open Questions:
Dishwashers Logo
503 people viewed this question
Top Dishwashers Experts
