tv went dead when trying to zoom in screen, will not come on now. keeps going back to standby, no sound or picture. tried pluging out tv for 6 hours, switching batteries, pressing picture and standby button together on remote control when turning on but no use.
-   After pressing the Zoom button on the remote the tv went to standby, then tried switching itself on but there was just a 'snowy' display and no picture. After turning off the tv, unplugging, and trying again the problem still persists. I have changed the batteries in the remote control but this hasn't worked. Could yo suggest anything else please?-   LEE SPRAGG
It sounds like you have a problem in the power supply or a short somewhere in the unit which is causing the power supply to stay in the standby mode to protect it. You say that it won't start with the remote, and I know this is simple, but it certainly would not hurt to try the controls on the unit, just in case the remote or pickup has a problem. If that doesn't work and you have repair skills, know how to use a DMM and check transistors, as well as knowledge of TV safety issues, you will have to troubleshoot the unit. This could be a shorted horizontal output transistor, a bad power supply or a short somewhere else in the unit. If the HOT checks bad I would replace the transistor and flyback and check all the associated components for any problems. If you find the HOT bad, that is probably your problem. If the HOT checks good, you may be beyond your skills and need to have the unit looked at by a qualified tech. That's your call. Good luck.
No remote, our child has somehow turned on child lock and possibly sleep mode. TV just stuck on...
(More)
No remote, our child has somehow turned on child lock and possibly sleep mode. TV just stuck on standby and now I've pushed in the menu button !! Help !!!
ive got a jcv tv (av-28GT1SJF) but the remote control recently broke. i was just wondering if i...
(More)
ive got a jcv tv (av-28GT1SJF) but the remote control recently broke. i was just wondering if i caould get the av function to work without the remote and if so how? i have tried flicking through the challens using the buttons on the tv but ive hav no luck, and ive also looked through the menu and cant find anything!any help would be great!thanks
