Ghost switch We have an old GE television (purchased in 1996) that works very well, but has suddenly developed the bad habit of turning itself on every evening about the same time. We had satellite TV hooked up to it, and after the installer left, the TV had this bad habit. I wouldn't be quite so bad if it was still on station, but for whatever reason, when it turns itself on, it also disconnects from the signal and we have to push "TV input" on the remote. I'm assuming there's some kind of timer that's built inside, but I don't have a clue as to how to access it. I've looked at the menu and there's asleep timer on it, but it's turned down as low as possible and it still does this. Is there a simple fix or do I need to have it either exorcised or euthanized?
    Scholar:
  • 142 Answers
Hello!
Your tv has bad solder connections at the tuner and microprocessor or you have a bad eeprom IC...or both. The eeprom IC is to the tv what ram is to your computer...memory. The tuner's RF shield\ground connections and the microprocessor's RF shield connections must be soldered. If the solder job at the tuner/micro has already been done then replace the units eeprom IC and your set will work.
Sounds like not an easy fix ,huh? It's actually very easy if you have any experience soldering. I did about 5 a week for 8 years or so. Every RCA\GE tv made between 1992 and 1996 needed to have their tuners and micro's shielding\grounds re-soldered. There was a class action lawsuit brought against RCA for this.
If your unit made it this long without having this repair done it's amazing...the problem was cracks would appear in the solder ( cheap solder ).
If your unit has had this service done...most had to be carried out when the sets were only 2 to 4 years old... then your sattelite technician recreated the problem just by unscrewing\screwing in the input cable to your set. He broke loose the solder connections again.
If your unit has good solder on the tuner and micro then replacing the eeprom IC will get your unit exorcised!!! Good luck! Please rate my solution...Thank you!
barneyluc
Posted on Oct 20, 2008
My 32" G.E. television can
I have had similar experiences. I have a VCR sitting near the television. I found that if I keep the VCR turned on then the TV stops changing channels by itself. If the VCR is turned off, then it starts again. Weird, but it worked for some reason.
Feb 15, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Tip
RCA GE telivisions
Rca and GE units that are between the age of 5 to 10 years old have a problem in their button panel unit will turn off by itself and menu scrolls no control of any of the functions after you turn it on replace front button panel ,ghost will go away
on Apr 27, 2010 | Televison & Video
When i switch my tv on it has a habit of switching itself off. The red light will still be on and a little green light below it flashes. some days it does it somedays it doesnt. Some times it does it once...
The television is switching itself off to protect itself because there is a problem with it. It may be a bad capacitor, which is usually the case but you have to catch it before it gets any worse. Because then the television will switch itself off and not come back on. The light will just continue to blink and on top of replacing the bad capacitor the entire board the capacitors are attached to might need to be replaced as well as the power supply and main board. Please do not keep turning your television on while it needs repair because it will put itself into a coma and contact a service provider asap.
Feb 05, 2011 | Toshiba 42PW33P 42" LCD TV
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
My 2004 Lincoln Towncar Signature suddenly developed this habit of setting off the alarm for no reason at all. No wind, no one touching it, etc. How can I bypass this alarm?
Mar 10, 2009 | 2004 Lincoln Town Car
I have a hotpoint refrigerator hss25gfpjww...symptoms I was having are ghost noises and water not working...the ice does work. I have replaced the water filter and the motherboard and the ghost noises have...
I have a GE. Same 2 problems. I still have the ghost, but I fixed the water. There is a coiled up tubing inside the refrigerator behind the vegetable drawer. It was frozen. I took the drawer out and turned the rerigerator off and left the door open for about 4 hours while we watched tv. Tried to run the water with no success. Just about to give up when all of a sudden water flowed. It happened 1 more time, but not for about 6 months now.
What's the ghost noise solution?
Jan 16, 2009 | GE GSH25JFR Side by Side Refrigerator
RCA 24V414T KEEPS TURNING OFF tv works great,channels, color, remote control etc just turns on about 5 mins and then shut down, again 2 minutes off, and then turns on back again, sometimes work all the...
it could be a ghost but most likely a bad solder connection , crystal(controls the eprom)(menu chip) , or the eprom chip itself will need to be replaced
Dec 01, 2008 | Televison & Video
TV turns itself off and back on
Your problem could be as simple as bad solder connections on the main high voltage transformer or in the sweep power supply. Without doing some probing around inside the set while it is turned on, this is a hard call my freind. If the set is over 5 to 8 years old, it is most likly age related as the Printed circuit boards, as they heat up and cool, will develop poor solder connections, ring cracks around the solder connectios and also heat related problems with some of the internel componets. This is a solid state TV set, and has no user replaceable parts inside. So if you have the know how around solid state TV circuits, and know how to solder, then maybe, just maybe you will be able to get this puppy to work just a little bit longer. if you do not, it is time im afraid to put this beast to rest and buy a new early holiday gift. Good Luck Please do not forget to rate this thread.
Nov 29, 2006 | GE 27GT616 27" TV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
