Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
LG LD-2160 dishwasher
Thought we bought salt but didn't. Filled the salt container with about 500g of detergent. The book says "Do not pour detergent into the salt container. This will destroy the water softener." Can any tell me what damage the detergent will do to the water softner and how to get the detergent out of the salt container without running the machine or doing any damage?
  • 641 Answers
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
Posted on Jun 28, 2006
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
How much salt should be added to the salt container
until it start to hit top of unit. bsc appliances uk spares or repairs
Feb 27, 2011 | LG 24 in. LD-12BW5 Free-standing...
Model No LD-14AWZ Wash rinse and dry lights flashing. IE flashes on display board.Model no LD-14AWZ
not sure if im on the rite page we have move into a house that has a disherwasher LG Model LD/14AW2 there was no instruction book left at the house cant seem to get it to work even though it looks quite a new dishwasher do anyone know where i could get a instruction book from thanks noelene
Jun 26, 2010 | LG 24 in. LD-12BW5 Free-standing...
Soap isn't rinsing clean. It looks like there's a
Hi this is not salt or detergent. This is likely to be lime/calcium. Go to home depot or a similar hardware store and buy a gallon of lime-away or similar product. Start the dishwasher on pots and pans then once the dishwasher has filled with water open the door and pour around 2 cups of lime-away in. Let the entire cycle run and then repeat this once a week until the problem clears up. Once the problem clears up repeat this once every 3 months to prevent the problem returning. If you have any other questions please feel free to comment. Mike
Feb 14, 2010 | Maytag MDB9600A Jetclean II Built-in...
Where do i put the salt
Pull out the lower basket and unscrew the large cap on the floor of the machine. Pour enough coarse salt into the aperture to nearly fill it and then wipe any salt spillage away from the aperture. Screw the cap back on and replace the basket.
For more details, I suggest that you click here for a free download of the user manual.
Please take a moment to rate my answer.
Dec 13, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
I put detergant accidently in salt section dishwasher
if yo run the dishwasher a few times it should flush it through
Sep 27, 2009 | Dishwashers
How much salt do you have to place into LG
just use dishwasher tabs.no salt needed or rinse aid,lots greener too...
Sep 19, 2009 | LG Dishwashers
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
640 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Marvin
Marvin
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
