Question about Hoover Vacuums
I need to replace the cord. There is a short near the housing.
  • 566 Answers
Hi may i suggest ? if you wish to renew the complete cord/wire? why not fit a longer length to facilitate more reach thro different rooms from the preferred wall socket ? the problem of short /breakage of wires within outer sleeve near casing is common on lots of vacs it is not a difficult job to replace if you are competant with wire and colour codes remove the access cover where wire enters vac then observe the attachment of each wire ? then disconnect faulty cable transfer the rubber tube that is normally fitted at entry point to vac at this point to new cable remove outer sleeve of new cable same length as old cable to reveal the inner wires then connect to vac sockets resecure cable to vac as previous dont forget the rubber tube? refit entry cover and fit a new 3 pin plug bs kite marked ? then away to vac the rooms? hope this helps
Posted on Oct 20, 2008
Kirby cord has a short in it
cable overheated at bottom joint, blown wire internally, will have to replace cable. phone 0800 294 4692 for new cable 27.95
Jan 13, 2013 | Kirby Sentria 192006 Power Cord
One day, I pressed the "on" button and it didn't start...had no problems whatsoever before.The inside hose is clear-fan turns-no visible breaks in the electrical cord or plug...
You need to measure for voltage inside the machine between the white wire and black wire from the power cord. If zero, the cord is likely broken at or near the plug end. This is a common problem if one pulls the plug by yanking on the cord instead of pulling on the plug directly. In any case, try cutting the cord off a little way back from the plug, and fit a new replacement plug from a home center or hardware store. If the voltage test above showed line voltage (115 volts AC in the US), then turn the switch to on, and measure for voltage between the white wire and the motor side of the switch. If good, then likely there is a motor brush problem or a broken winding in the motor. Repair of this usually requires dis-assembly of the housing around the motor. Hope this helps!
Oct 04, 2010 | Kirby Generation 3 Bagged Upright Vacuum
The unit will not run.
Check cord on machine. Plug in and turn on wriggle cord near powerpoint and then near machine and all over, if it starts and stops the cord needs replacing
May 02, 2010 | Kirby G4 Bagged Upright Vacuum
How do I replace the Powercord on a Fantom XT64K Vacuum. The powercord shorted where is comes out of teh housing. I need to open up the unit & replace but need a service manual of instructions. Thanks...
I have done this several times, it's some what simple just take the unit apart and use the old diogram to replace the new one. Or take a digital photo of it opened so you have your own scematic. You should be able to purchess the cord at your local hardware store "be sure you get the same insulated cord" the numbers will be located all down the old cord. Also very important. If you have never done this before I recomend you have someone with this type of knowledge. For safty reasons. good luck and hope you save some $$$$$
Nov 14, 2009 | Vacuums
Kenmore/Sears Progressive 116 How to get housing off to replace cord
There are four screws, two at the front and two at the back under the step bar that rewinds the cord.  It lifts off from the bottom.  Be careful not to snap off the tabs.
Sep 20, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Replacing the electical cord on Kenmore Progressive Vacuum
To the right of where the cord comes out of the machine is a large screw. Remove it, and slide the upper handle assembly free.
Then, on the front of the machine, remove the screws located toward the top of the vacuum just inside the bag chamber cover. This will allow the front panel to be removed, giving you access to the cord from the front.
-R
Sep 15, 2008 | Kenmore 31913 Progressive Direct Drive...
Miele s558 Silver Moon
It is not generally necessary to replace the entire cord reel, although occasionally it is.
Here's the quick and easy DIY way to make your cord reel work again: you will need a #2 phillips head screwdriver, any flat head screwdriver, a pair of scissors, and a zip-tie.
First, remove the bag compartment lid by gently prying the hinge parts inward with the flathead screwdriver until you can lift it free. Remove bag and exhaust filter, and then remove the two screws holding the rear control panel on. Lift the front of the control panel upward until you hear a horrible unpleasant crunching noise. You didn't break it.
Lift that free, and remove all screws from the top of the main housing. (I believe there are 6 or so... but I can't remember off the top of my head.) The housing should then lift free.
You should now be able to see your cord reel. see if it wiggles back and forth along the central axle. If it does, you'll want to place the zip tie around the side of the axle which is away from the large round copper contacts which look almost like leaf springs. This will ensure that the contacts make electrical contact again. Cut off the excess zip-tie.
When putting the parts all back together, it is essentially a reverse of the disassembly, but be sure that you thread the cord through the hole in the back of the housing before you attempt to screw the housing down, or you will be very sad; both because you'll have to disassemble it again, and because you'll probably jack up your cord and have to replace the reel, which is what we're trying to avoid.
Test machine. If it works: party. If not, you will have to replace the cord reel.
For further clarification on the process, contact me.
Good luck,
-R
Aug 17, 2008 | Miele s558 Silver Moon Vacuum
Need to replace power cord and can't find how to open canister to replace
I had the same problem and could not find the other screws. You need to pry off the power cord retraction button, you will find two more screws under there. It's pretty easy after that!!!!
Jun 02, 2008 | Kenmore 22612 Bagged Canister Vacuum
Vacuums Logo
71 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
