Question about GIMP GNU Image Manipulation Program
Gimp install I've just installed Gimp on my Windows Vista Home Premium computer. And it just dose'nt funger. Every time I try to open it I get the message "Gimp 2.6exe has stoped to funger" or I don't know what it's called in english. But then it tells me that windows has shut down the program and is searching for soultions. But it can't find any and I don't know what to do? PLEASE HELP ME I NEED GIMP!!
    Scholar:
  • 90 Answers
Hi there. Common error. Just uninstall GIMP, re-boot and then reinstall only from www.gimp.com (nowhere else). That should do it.
Posted on Aug 03, 2009
Did a clean install of my laptop. Windows does not acknowledge Windows Vista Home Premium
There will be a sticker on the laptop wi the product key. It will be in the format of xxxx-xxxx-xxxx-xxxx-xxxx Sometimes the sticker will be under the battery. If the sticker is not on the laptop it was either removed, or you need to make a complaint with Walmart.
Apr 17, 2013 | Dell Inspiron Computers & Internet
How do I reinstall Windows Vista Home Premium without a disk?
Most manufactured computers has a recovery partition installed to the computer. Suggest you access their support site for further info.
Dec 20, 2012 | Microsoft Windows Vista Home Premium SP1...
Hp officejet j3640 not working on windows vista. I had the printer working and when disconnected when moved it doesn't work. I've tried uninstalling and reinstalling the driver several times....
first check your is working or not
then open control panel - administrative tools - services - printer spooler services - double click the services - click stop button - next click start button - choose automatic then give the print if not coming connect other pc to ur printer check printer
Oct 29, 2011 | Dell Inspiron 531 Athlon 64 X2 4400+...
I'm using vista home premium os, however the problem I enccounter is once you install software which is compatible for windows NT, xp home and windows 2000, the software the one I installed is not properly...
Yes, if you use a Virtual Machine, you can install the version of windows you wish to work with, install the software, and it should work just fine.
You will however need a genuine copy of windows to install in the virtual machine.
You may be able to find an image of the OS you need, or a snapshot of an OS, to load into the VM, it all depends on the type of VM you are going to use
Sep 30, 2010 | Microsoft Windows Vista Home Premium with...
How to fix error code 646 microsoft windows vista home premium software
* The solution, in a nutshell, is to disable your firewall. If you’re using McAfee Personal Firewall Plus, F-Secure Internet Security, Norton Internet Security or another Firewall vendor, see its respective support page for assistance in disabling it (temporarily). If you’re using the built-in Vista Firewall, keep reading.
* Open the Control Panel and select Security.
* Select Turn Windows Firewall on or off.
* Select Off (not recommended), click Apply and then OK.
* Back at the Windows Update screen, click the Try again button.
* The download(s) and installation should start…
* and this time successfully install. If a restart is required, make sure to re-enable your Firewall once your PC restarts.
* Though this solution will work for most Vista Update errors
Jun 24, 2010 | Microsoft Windows? Vista Home Premium...
I cannot install ethernet driver of hp compaq d530. Where can i find it?
Hello: I hope the following information is helpful.
If you are trying to install the driver for the Broadcom ethernet NIC that was pre-installed (NOT an ethernet card that you purchased and installed yourself), there is a softpack (updated driver installation) download available from HP/Compaq. It will install the driver automatically for you, just download it from the link below and run the ".exe" file.
IMPORTANT: Check to be sure that your current Operating System, and model of the network device you are trying to install, are BOTH listed below BEFORE you download!
This is a software / driver update for the HP Compaq d530 ultra-slim desktop: All Models
Supported network devices:
BCM5906M Broadcom 10/100/1000 5782 based NIC Broadcom 570x 10/100 Integrated controller Broadcom NetXtreme Gigabit Ethernet 5782 Broadcom NetXtreme Gigabit Ethernet PCI-Express NetXtreme(tm) 10/100/1000 Gb NIC
Supported Operating Systems: Microsoft Windows 2000 Microsoft Windows 98 Microsoft Windows NT 4.0 Microsoft Windows Vista Business 32 Edition Microsoft Windows Vista Business 64 Edition Microsoft Windows Vista Enterprise 32 Edition Microsoft Windows Vista Enterprise 64 Edition Microsoft Windows Vista Home Basic 32 Edition Microsoft Windows Vista Home Basic 64 Edition Microsoft Windows Vista Home Premium 32 Edition Microsoft Windows Vista Home Premium 64 Edition Microsoft Windows Vista Starter 32 Edition Microsoft Windows Vista Ultimate 32 Edition Microsoft Windows Vista Ultimate 64 Edition Microsoft Windows XP Home Edition Microsoft Windows XP Professional Microsoft Windows XP Professional x64 EditionINSTALLATION INSTRUCTIONS: 1. Download the file by clicking the "Download" or "Obtain Software" button and saving the file to a folder on your hard drive (make a note of the folder where the downloaded file is saved). 2. Double-click the downloaded file and follow the on-screen instructions.LINK where file can be downloaded:HP/Compaq Support-Broadcom Driver download
Again, I hope this information is what you neededto install your network device. Should this not answer your question, please come back, provide more details of your problem, and we will be happy to help!Best of luck to you!
Jun 23, 2010 | HP Compaq d530 Ultra Slim PC Desktop
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Sep 21, 2009 | Computers & Internet
I have vista home premium, yesterday i installed vista service pack 1, after completion it recommended to restart computer to install important updates bt after doing this nw computer is nt able to...
Good advice from the first expert. After reinstalling the operating system, allow Vista to install updates from the Microsoft site instead of installing from a disk. You did not specify if you had done this. If given a choice of updates needed for Vista, choose only the service pack and no other software initially. After it installs, you can continue on and choose to install additional updates from the Microsoft site.
Jul 10, 2009 | Microsoft Windows Vista Ultimate Edition
Open Questions:
See all GIMP GNU Image Manipulation Program Questions
GIMP GNU Image Manipulation Program Logo
119 people viewed this question
Top GIMP Computers & Internet Experts
Rick Moore
Rick Moore
Alun Cox
Are you a GIMP Computer and Internet Expert? Answer questions, earn points and help others
